-   -   964 Cruise Servo pinout spec (http://forums.pelicanparts.com/porsche-911-technical-forum/649694-964-cruise-servo-pinout-spec.html)
Dr J 01-08-2012 08:57 PM
Can anyone help me with the pinout specs for the 964 cruise control servo? Its a 7 pin connector, 4 male and 3 female.
Thanks!
jmod 01-08-2012 11:50 PM
Dr J,
Not sure if this is legible, but is this the sort of thing you are looking for?http://forums.pelicanparts.com/uploa...1326095409.jpg
Dr J 01-09-2012 07:40 AM
Thanks Jim, that's a good start! It looks like the 7-pin connector is the Drive Cruise Control to the upper left of the diagram.
The next step and my question for all, and the reason for the post is that I want to be able to control the drive independently (imagine I am designing the Cruise Control Controller, or want to use it for robotics).
Would I put a voltage between 0 and 12 at M+ and ground at M- to get a proportional move? Or is it like a servo that uses PWM to determine how much to move the cable?
What are Pot1 A, S, and E? Is control done through these inputs with a constant voltage at M+, M-?
Dr J 01-12-2012 03:30 PM
Anyone?
