Lots of play in the gearbox in all gears?
The gearbox in my 89' SAE is all loose even when in gear. It's to the point where if I park it in 1st and someone gets in it's possible to confuse it to be in neutral (makes for some funny/scary moments when someone else trys to start it)! I replaced 1 cup bushing as when I took the car out of its long slumber and cleaned up the shift boot I found the shredded bushing in the bottom of the shifter. The play is still there the one I replaced was a greyish one that you can see the top of it if you lift the shift boot up.
Any ideas?
Old 01-10-2012, 08:01 PM
ivangene's Avatar
have you looked at your coupler?
Ed M
86' Coupe
Old 01-10-2012, 08:03 PM
RETIRED
Joe Bob's Avatar
Had a GF like that once.....but I agree the coupler is the first place to look.
2012 ML350 3.0 Turbo Diesel
Old 01-10-2012, 08:44 PM
Funny thing is I bought the coupler w/ cup bushing and lost it. Was hoping it wouldn't cause problems down the road.
Guess I might aswell replace the O-Rings while I'm down there.
Old 01-10-2012, 08:59 PM
ivangene's Avatar
O'rings?
Ed M
86' Coupe
Old 01-11-2012, 05:19 AM
