-   -   Blocking off Center Outside Vent (http://forums.pelicanparts.com/porsche-911-technical-forum/649973-blocking-off-center-outside-vent.html)
NoLift911 01-10-2012 10:13 AM
Has anyone done this? I was thinking of taking the carcass of the HVAC blower unit and modding it with a drain tub etc but I just don't need to do all of that just blocking off the vent is better.
I want to maintain the stock appearance so I am wondering what type of material is best to use in conjunction with the OEM mesh screen, that looks OEM and is water tight/resistant.
Thanks -
NoLift911 01-12-2012 06:09 AM
Anyone?
aston@ultrasw.c 01-12-2012 06:25 AM
What's the goal?
I removed everything associated with heat, vent and AC to reduce weight.
I made a simple cover from aluminum sheet using the mesh as a template. The cover had a soft rubber backing to seal against the opening.
In the summer I was dying from the heat out here in the desert, so I made an aluminum plenum to direct the air from the opening into the center vent. I was amazed how much more air flowed through my home made duct in comparison with the stock set up.
If you like I can take pics later.
NoLift911 01-12-2012 06:38 AM
Pics would be great.
Everything is removed. Goal is to prevent water from getting into trunk.
AFCuk 01-13-2012 05:07 PM
I used the tube out of a bike tyre.
Cut it to size and shape, fits nice,water proof and can see its there....Black car;)
Paul
aston@ultrasw.c 01-15-2012 07:52 AM
Here is my block-off plate for use in the winter (below 60F!) and the plenum below the opening.
The design is basically a copy of a fiberglass part, Smart Racing I think, that was way expensive.
http://forums.pelicanparts.com/uploa...1326645676.jpg
Here you can see the drain fitting, but the hose is MIA
http://forums.pelicanparts.com/uploa...1326645760.jpg
This simple box gets lots of airflow, but in the summer I wanted more so squeezed one of those in-line blowers behind.
http://forums.pelicanparts.com/uploa...1326645868.jpg
Finally i had some mandrel bends lying around, so i made a nozzle...
http://forums.pelicanparts.com/uploa...1326646068.jpg
OK - what am I going to make today ;-)
