-   -   How to tell if 3.0 SC chain tensioners have upgraded with 3.2 Carrera tensioners? (http://forums.pelicanparts.com/porsche-911-technical-forum/649995-how-tell-if-3-0-sc-chain-tensioners-have-upgraded-3-2-carrera-tensioners.html)
tobsam 01-10-2012 12:43 PM
I am sure there are previous posts on here about this but I cannot find them anywhere.
I want to check to see if my 3.0 SC has had the upgraded 3.2 Carrera chain tensioners fitted to the engine. Is there a quick and easy check that can be carried out to check for this?
I believe I have read in the past about checking for the oil feed pipes but cannot remember where these pipes should be located on the engine.
nick_911 01-10-2012 12:49 PM
Hi steve ,
The simple way is to see if there are hard oil lines going to the chain covers. They will have a banjo fitting on the face of the cover also.
Sorry no pics but it is easy to spot.
Cheers
Nick
lindy 911 01-10-2012 12:58 PM
The oil lines that indicate pressure fed tensioners are on the face of the chain box covers easily visible.http://forums.pelicanparts.com/uploa...1326229100.jpg
tobsam 01-10-2012 01:05 PM
Thanks guys. :)
That was really helpful and like lindy 911 says is a very quick and easy way to check if they have been upgraded in the past.
I will check to see if my engine has the solid lines going to the covers in the morning.
Thanks again
mack6820 01-10-2012 04:16 PM
nice! I think it just moved a little.....
