Guidance Needed
I have a 1987 911. I have the top part of the engine off all of the way down to the engine shroud. While I am at this point do you guys recommend I change out any of the hoses. My car is running fine with no leaks. But as a preventive measure while the top of the engine is off, what hoses, if any, do you guys recommend I change out from a preventive maintenance standpoint.
Thanks for the assistance |
squeeze them - and look/feel for any cracks, esp. the part under the hose clamps
also, shop vac out the crud under the shroud, which will be blocking air flow to the heads |
Definitely change out the fuel lines.
two styles of fuel hose. one type looks like it's wrapped and one type is smooth hose. the smooth ones are usually full if mini cracks. look close with a flashlight.
Guys, thanks so much for the guidance so far. I will do as all of you have suggested
Damn RWebb:
that picture you posted above got me scared to death |
I have more if anyone needs extra convincing.
I also hear that most fire extinguishers are inadequate for an engine fire... So, change the rubber fuel hoses, the rubber brake hoses, and carry a Halotron fire extinguisher as it can help. |
+1 on the fuel lines.
What else are you planning to do while it's off? |
| All times are GMT -8. The time now is 09:04 PM. |
