Upgrade oilpump on early S?
Just finished disconnecting everything to drop the engine tomorrow. I now have basically all parts to do the rebuild but one thing is nagging me; should I upgrade the oilpump (and pressure valves)?
I did not have any complaints about oil pressure but I am a bit anal in getting things right. Are there any definitive advantages? And if so, should I get a used one or a new pump?
Peter
'13 981S
'73 911T
'05 996 4S cab, now gone
'70 911S Targa, now gone
Old 04-06-2002, 01:21 PM
Early_S_Man's Avatar
Porsche Crest
Peter,
You can do the 'bypass mod' with the new plungers and spring & guide ... without having to update the oil pump. That change alone reduces the load on the scavenge pump and intermediate shaft, and probably saves a hp or two as the result.
The benefit of the later '76 Turbo/SC, '84 Carrera, or 964 pump is greater pressure pump volume and higher resulting oil pressure.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 04-06-2002, 02:23 PM
Peter,
What is it going to cost you to do this rebuild?
Old 04-06-2002, 02:56 PM
Cool
Thanks Warren, interesting thought. I am going to consider this.
Costs: I stopped counting, it's kind of a black hole moneywise. I am going to put in new P/C's, intermediate gears, chainwheels, big/little end rod bearings, main bearings and some other work. Heads were done last year together with MFI pump, t-bodies and cams. As long as the girlfriend does not find out.. ;-)
Peter
'13 981S
'73 911T
Old 04-07-2002, 12:55 AM
