Thread Spec's for Battery clamp???Help!
Hi,just need the size and spec's for the bolt that holds the battery hold-down clamp for a 83SC. Thanks in advance!!! hank911....
Bolt Size
Hank911,
The correct size on the battery hold down is M8 x 20. |
M8 X 20mm I'm assuming it is a standard thread pitch. You can get them at Performance or Pelican for a couple bucks.
Noel |
| All times are GMT -8. The time now is 10:15 PM. |
