-   -   911 sc: ignition switch on and the starter randomly engages???????? this is scary. (http://forums.pelicanparts.com/porsche-911-technical-forum/650863-911-sc-ignition-switch-starter-randomly-engages-scary.html)
marlinaness 01-14-2012 03:38 PM
I tried searching for this, but no luck. Just installed an engine into an 82 911sc.
With the ignition switch on, the starter will randomly and every second engage the starter for one quick second and then does it on and off.
recommendations?
thanks in advance
Marlin
JJ 911SC 01-14-2012 04:08 PM
recommendations?
thanks in advance
Marlin
Which engine, 3.0 or 3.2?
marlinaness 01-14-2012 08:22 PM
81 SC 3.0 into an 82 SC body.
I originally thought it was the key ignition switch. But, the starter was turning on without touching the key once I turned it to the on position. On and off, on and off almost like a relay was slowly cycling. very strange indeed. Just got a Bentley manual today and will start looking. Also, although it started and ran, I had a fuel leak. After I fixed the leak, it didn't start anymore and looks like the fuel pump is gone. No noise even when connected directly to the battery.
psalt 01-15-2012 06:57 AM
If the car originally had A/C (most), check the little metal relay in the smugglers box, it can cause this symptom.
jstobo 01-15-2012 07:30 AM
Check the insulation of the wires at the starter. If the insulation is worn on the yellow wire and the battery cable then if they touch the starter will engage. This short bypasses the ignition switch.
