hursty
headlights
hi guy's
i want to change my headlight lenses to lhd,i have an option to buy h1 or h4 type lenses ,question is what's the differance ?. my porsche is 911-964-c4-1990,
thanks
hursty
Old 01-22-2012, 08:15 AM
my understanding is that the lens needs to match the bulb/reflector assembly behind it.
An H4 has one bulb with two filaments that provide both high and low beams. H1, on the other hand, has two bulbs, one for high beam and the other for low.
Some headlights also have a separate small bulb to provide parking light illumination.
So, you need to be sure the LHD lens matches the assembly's innards. MOST lenses will have "h4" or "h1" inscribed in the glass
Old 01-22-2012, 08:28 AM
Drisump's Avatar
My understanding is that the H1 reflector allows separate adjustment for Hi and Lo beams....but that wouldn't be a function of the lens. My natural reaction would be to replace the RHD lens to a LHD lens but not try to change anything fundamental. In other words, if it came with RHD H4's, change out to LHD H4's...if it came with H1's, stick with H1's. Cheers
Old 01-22-2012, 08:33 AM
