In maintenance phase
daniel911T's Avatar
Somewhat urgent help needed! Seat belt mounting
I got a nice set of seats from a Carrera and the matching seat belts. I had read on PP that all the '69 bodies had the necessary holes drilled and tapped for 3pt seat belts because they were a ROW option.
I just exposed my passenger side door pillar. No hole. Could someone please take a good pic of where the shoulder harness mounts, and some measurements. I think I'm going to have to drill and tap this myself, I just need to know where the holes are supposed to be.
Secondly, my car has some mickey mouse rig for the lower outboard mounting points. I can't find any holes in the body in the right places. Where (in a '69) are the seat belts anchored?
Thanks for the help!
-Dan
1969 911T (Getting a 72E heart transplant)
2004 Volvo XC70
Gone, but not forgotten:1971 Bug, 1978 Bus, 1982 Westy, 1996 GTi, 2000 Audi A4 2.8, 2001 Jetta Wolfsburg 1.8T, 2002 Audi allroad 2.7T, 2010 Jetta SportWagen TDi, and a couple of short lived 914s.
Old 01-16-2012, 06:21 PM
My 69 had the holes for the inertia reel drilled and tapped midway on the rear seats. They had a plug in them. They are tapped with 7/16" fine treads not metric. Look in the rear wheel wheel. You might be able to see them there. The problem is that there is not a reinforced mounting for the receivers to mount behind the emergency brake, As you know, the 69 receivers are mounted on the seat rail. I would not add the receivers without reinforcing the floor pan.
69 911 2.3Ez
85 928S
Old 01-17-2012, 02:07 PM
Here's a pic
69 911 2.3Ez
85 928S
Old 01-17-2012, 02:15 PM
daniel911T's Avatar
The seats have receivers integrated. I have the hole for the inertia reel, but none for shoulder attachment.
2004 Volvo XC70
Old 01-17-2012, 02:18 PM
Okay I misunderstood. My connection is on the pillar right above the seat. My car came with fixed shoulder belts so the mounting was already there. The center of the mounting bolt is 4.5" down from the door frame. Surprised that there is no mounting hole already there. Good luck.
69 911 2.3Ez
85 928S
Old 01-17-2012, 05:53 PM
arrivederci's Avatar
Here's a pic from my '72 as I was cleaning off the old glue/paint. The center is 4 1/2" above the lower edge of the rear window.
- '72 911T
- '81 911SC Euro
Old 01-17-2012, 06:42 PM
All 3 of my 69's have them. Gotta be there. Don't they?
On the Targa they were behind the inside vent material on the bar.
Old 01-17-2012, 07:22 PM
Classic's Avatar
Dan, answered to your other thread, but mine is the same as above.
Can you post a photo of your B pillar, so we can work this out for you?
Of note the B pillar has a very thin felt like material under the vinyl to give some padding, you've removed that right?
Tony
Classic 1969 911T
Old 01-18-2012, 01:11 PM
Rennch on YouTube
emptyo's Avatar
Send a message via AIM to emptyo Send a message via Yahoo to emptyo
Dan, did you ever sort this out? I'm in the same situation.
Michael O'Neal -
69 RSR Clone(ish) - The build: http://bit.ly/69porschersr
69 911S Blasphemy Build on YouTube
Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/
Old 04-10-2013, 01:58 PM
daniel911T's Avatar
I'm sorry I don't have any pictures, but here's how I worked it out:
The inertia reel mounting hole and locating hole were there and went in pretty easy. The pillar does not have a hole. This was a major bummer.
What I did was drill a hole in the body directly above the inertia reel and as close to the window trim piece as I could get it. I got two massive stainless steel fender washers and put one on the inside and one on the outside. I used a heavy duty lock washer and used red loctite on the nut, which ends up being in the rear wheel well near the door jamb. (I used the same bolt that would have gone into the pillar)
It's not perfect, but it works. It puts the shoulder belt rotating piece a bit below shoulder level, but it does play out the belt smoothly and retracts just fine. It also locks properly under braking, which I'm pretty sure is due to the inertia reel being properly angled. All other mounting locations were already in the car and worked normally. Obviously, I'm willing to risk my life on it. (The ss fender washers I used are 4" in diameter... I don't see those pulling through the body.)
Final note: I found the intended location for the 3pt belts in my car. It's actually on the rear deck. The parts manual shows the manual 3pt belts mounting back there and they have the strange, unique to seatbelts, threads in the holes. A later model retractable belt has no hope of reaching back there. Just more proof that my car is an odd, very early '69, car. I have a few of those quirks.
Best of luck! I'm sorry it took me so long to get back to you, I'm on an Aircraft Carrier at sea right now... We're pretty busy.
-Dan
2004 Volvo XC70
Old 04-12-2013, 07:42 AM
