SSI Fasteners
What are the proper fasteners to use with SSI headers?
Steel barrel nuts on the studs where there is access throught the holes (5), with or without washers? The rest of the studs? Just M8 steel nuts? Washers? Thanks for the help as always, Wade
-Wade 1972 Targa, nothing matching. Looking for motor 6124265 and transmission 7720299 |
83 911 Production Cab #10
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
barrel nuts and copper coated steel M8 w/12mm hex. he sends a bent 12mm box end with the exchangers. no washers. porsche didn't use them, so....
Diss Member
Another thumbs up for the copper nuts.
Also forget the aluminum based antiseize. Either use copper or nickle based antiseize.
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
Thanks everyone!
Wade
