too many projects 1983 sc
56 nomad's Avatar
Help removing masking tape residue from leather
i need some help...alright , i bought some leather door panels and the PO had put "masking" tape on the speaker grills to hold them in place...needles to say the adhesive is doing its job all too well. i would like some advice as to what others have used to get glue off with out harming the color on the leather.
i would like advice as to what has worked for you and not speculation as i don't want to have to redye them.
what would you recommend to clean the grime off them?
1 step forward and you know the rest! we need a smile holding a gun to his head!!!!
regards, ben one more project among the many
Old 07-15-2012, 01:33 PM
Classic's Avatar
Wax and grease remover, just test it to ensure color fastness
Classic 1969 911T
Old 07-15-2012, 02:07 PM
motorcop's Avatar
Product named Goo Gone, available at most auto parts stores.
Old 07-15-2012, 02:11 PM
56 nomad's Avatar
have you used it some posts say not good on leather...
Old 07-15-2012, 02:20 PM
56 nomad's Avatar
do you have a brand that you have used.. thanks , ben
Old 07-15-2012, 02:21 PM
French Import
zippy_gg's Avatar
I have used Goo-Gone on my carpet and leather to remove excess glue from overspray when I redid my interior; no problem on leather, but then again I was careful and just used the product and wiped off immediately.
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 07-15-2012, 03:27 PM
56 nomad's Avatar
this dried masking tape residue..ben
Old 07-15-2012, 05:08 PM
Classic's Avatar
any brand will do, go gone's not bad either, just check on an inconspicuous spot first to check for color fastness
Classic 1969 911T
Old 07-15-2012, 05:58 PM
JoeyD911's Avatar
There is a product called GOOF OFF that has worked for me on anything I've tried to remove, just as others say, test for color fastness first. Spray whatever you use on the rag and wipe clean, not directly on the surface to be cleaned.
Joe D
L.I. NY
82 911 SC 3.0
Swartzmetalic
Old 07-16-2012, 06:47 AM
cnielsen's Avatar
My upholstery guy recommends using white gas. It's the cooking/heating gas you use for camping. I've tried it and it works well for all types of glues. I would advise testing it though on a hidden area first.
'67 911S
'69 911S,
'70 911ST
'73 911T Targa Signal Yellow
'78 911SC backdate
Old 07-16-2012, 06:48 AM
56 nomad's Avatar
thanks to all....will report back, ben
Old 07-16-2012, 07:02 AM
Porsche fanatic
jager911's Avatar
Should be same as denatured alcohol, I used it to remove glue residue on paint without any ill-effects. You can get it at Home Depot.
'56 Speedster Guards Red
'74 911 IROC- 3.2L, 22/28 tbars, 22 sways, Bilsteins, Big Reds, Seineshift, headers/M&K, slicks, 17" Fuchs, SW
'95 993 -H&R coilovers, turbo sways, GT2 wing, Fabspeed
'74 911 Targa, 87 944T, '75 911 Anniversary Edition-sold
Old 07-16-2012, 07:33 AM
try WD 40. It's very good for removing adhesive residue. I've never used in on leather. So, I would go easy at first.
Bob,
59 A coupe
67 911S
04 R1150RS
Old 07-16-2012, 07:41 AM
Try any cooking oil, olive, canola or what ever is in the kitchen.
Free will is doing what we must joyfully.
Jung
'68 912 Coupe
'82 SC sunroof
Old 07-16-2012, 10:29 AM
baby oil too or other oil as above. Let it sit and it slowly should come off. There is a rubber cement remover product too but any solvents might over clean the spot and make it noticeable.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 07-16-2012, 10:38 AM
How about good old fashioned Saddle Soap? I use it regularly on my interior. Low impact and softens the leather as well.
Christopher Mahalick
1984 911 Targa, 1974 Lotus Europa TCS
2001 BMW 530i(5spd!), Ducati 900 SS/SP
2006 Kawasaki Ninja 250, 2015 Yamaha R3
1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750
Old 07-16-2012, 11:13 AM
