Windshield wipers won't turn off!
So I am out putting some miles on my recent 3.0 into my 73 and it starts to rain. I turn on my wipers and when it finally stops raining, the wipers stay on when I put them in the off position ... WTF? Any help would be appreciated. On a side note, the R888's I have behaved very well in the wet.
Old 01-26-2012, 09:36 AM
Dumb question, but do you have the setting for delayed wipers that may still be on. I don't know if that was available in 1973.
Christopher Mahalick
1984 911 Targa, 1974 Lotus Europa TCS
2001 BMW 530i(5spd!), Ducati 900 SS/SP
2006 Kawasaki Ninja 250, 2015 Yamaha R3
1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750
Old 01-26-2012, 09:47 AM
That sounds like the wiper switch/stalk if messed up. Pull the fuse until you can R&R. But make sutre that you keep the fuse handy for the next rain shower.
Old 01-26-2012, 10:05 AM
CCM911, there are three settings; off, low, high on a 73, non of that fancy stuff.
4495, thanks did that finally.
There has to be an "easy" fix, right?
Old 01-26-2012, 10:27 AM
Dublinoh's Avatar
Per this site:
"Replace your windshield wiper switch with a new one. Replacement is fairly easy and straightforward, but requires steering wheel removal. For more information, please see our Pelican Technical Article, Steering Wheel Removal and Installation."
Might try some electrical cleaning spray before replacing? I don't know if you would have to remove it to do that. Good luck
Old 01-26-2012, 11:07 AM
Reiver
Reiver's Avatar
Try the spray tech, worked for me, or move to Seattle whichever is easiest
Old 01-26-2012, 03:36 PM
Diss Member
Quicksilver's Avatar
Check you grounds. The wiper motor always has power because it needs to keep running after it is switched off until it reaches its parking position. I've seen loose or dirty grounds cause the wipers to not turn off... or the fun one: Turn on each time you hit a bump.
Check the ground stud right next to the battery. Check the crimp ends for corrosion. There may be other places to check on the early cars.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 01-26-2012, 04:37 PM
Thanks for the suggestions, I will give them a try and report back, and hopefully won't have to move to Seattle.
Old 01-27-2012, 04:30 AM
The electrical contact cleaner spray did the trick, just in case anyone else had the same issue.
Per this site:
Old 01-27-2012, 01:37 PM
