-   -   Anybody weld in some RSR strut bar mounts ? (http://forums.pelicanparts.com/porsche-911-technical-forum/652275-anybody-weld-some-rsr-strut-bar-mounts.html)
wildcat077 01-20-2012 08:23 AM
Hey guys,
I plan on welding in some RSR strut bar brackets that i just received from TRE and it seems there is not much clearance on the driver's side between the shock tower and where the neck from the fuel tank and the junction hose from the filler neck are ...
I kind of figured i would have to remove the tank to weld in the driver's side bracket but did anybody do this themselves and do you have any tips before i get into this project ?
Thank you !
Cheers !
Phil
TRE Cup 01-20-2012 03:25 PM
Hi
After you called this a.m., one of our clients wanted one installed, with a stock gas tank.
If you push the gas tank filler neck slightly inwards, it all fits without mods to the bracket. We moved the bracket back a little from standard install location- see these pics
http://forums.pelicanparts.com/uploa...1327105508.jpg
http://forums.pelicanparts.com/uploa...1327105519.jpg
http://forums.pelicanparts.com/uploa...1327105530.jpg
http://forums.pelicanparts.com/uploa...1327105546.jpg
wildcat077 01-20-2012 03:40 PM
Thank you Dave,
You're the best !
I sure wasn`t expecting such a quick solution ...
Guess when you deal with professionals,you get professional service :)
Cheers !
Phil
Fishcop 01-20-2012 05:11 PM
Oh oh, I welded mine in without reference to the tank...
Flieger 01-20-2012 05:14 PM
Mine is center-fill. :)
advtracing 01-20-2012 05:51 PM
Did you weld in the rsr braces with the tank in?
wildcat077 01-20-2012 06:13 PM
No, the tank is coming out before i weld up the brackets !
I certainly don't want to blow up my car and the garage which is part of my house ... lol
Cheers !
Phil
safe 01-21-2012 01:16 AM
Does the RSR type strut bar have a better function than the bolt on type?
I'm fitting coilovers to my car and are considering what kind of modifications I need to do in the front.
wildcat077 01-21-2012 05:36 AM
I'm doing it because i had the Weltmeister strut bar with the cheap mounting brackets that i had to reweld twice ...
It also frees up your strut mounting bolts as your strut bar is no longer attached to the strut plate.In my case i'm installing some Tarret camber plates and i wanted the cleaner look in the trunk area.
You can PM Dave at TRE,he's very helpful and should be able to answer your question !
Cheers !
Phil
DaddyGlenn 01-21-2012 05:57 AM
I think you'll be okay. In a wost case scenario, you could trim the tank neck and use a longer rubber hose that would have some give.
Fishcop 01-21-2012 09:57 PM
Good point. Must remember to use the hack saw and not a cut-off wheel ;)
pksystems 01-22-2012 04:17 AM
subbed.... I noticed this issue after I made/welded in my brackets... :( I guess I'll have to notch the left bracket
uptheorg 06-21-2014 01:02 PM
To do this on my 1984 Carrera, we had to move the fuel lines and remount the fuse box about 4 inches towards the nose. Here's a shot of the finished product:
http://i756.photobucket.com/albums/x...ps7292c7bf.jpg
http://i756.photobucket.com/albums/x...ps2c4f0d0c.jpg
