Help.. removal center reflector
Restoring tail end and dont want to crack the center reflector
on remaval. All other items, engine etc are remove. I have good access. Wht's the best way to remove without cracking Thanks for assistance Frank |
Center reflector
When I removed the one on my '80SC, I used a thin screwdriver and gently pried on each of the reinforced areas where the mounting studs are attached. By working from stud to stud and only moving each a small amount I was able to get it off undamaged. The reflector on my car was attached by way of metal clips and though the studs were threaded, they did not have nuts on the back side, they were only pressed into place. Be sure to double check your car to be certain it is made the same way.
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning |
reflector removal
Fred
Thanks for your insight,mine are same as yours.I will apply some light oil spray to ease the movement.I thought that was the only way but concerned about the pressure.Hope to have success. Much appreciation Frank |
