tool source?
I am getting ready to remove the doors on my 71 coupe project. Seems the hinges are held on by a 12 point bolt. I did a search and found these to be a 12 point "triple square" type bolt. Now the question is,
Where do I buy some of these bit? I searched the sites of Chraftsman, MAC, Snap-On, harbour Freight, etc. I even called several auto tool stores here in the DC area. I can not locate them anywhere. I know that some of you that own later cars need them for CV axle work. I assume that these bits can be purchaced. Any sources would be a great help. Jamie |
Bought my set at the local Pepboys store. Needed it for the 12-point bolts on the Porsche flywheel.
I am very sure Snapon or MAC have them. Napa... too. |
if you just remove the hinge pins, there's no lineup problems on reinstallation and no chipped paint around the bolt heads.
Have you tried Pelican. I believe our host has them for sale.
Thanks for the sources. I will check my local Pep-boys. If not I will be ordering from Pelican. It seems I did not see them on the site when I looked for the tools. I have to admit I was not looking in the right spot.
JW- I am planning on completely removing the hinges. I have some rust repair to do in that area. Besides, I will be hanging and aligning some Glass doors as the project progresses. Thanks for all the help. http://www.pelicanparts.com/support/smileys/wat6.gif Jamie http://www.pelicanparts.com/support/smileys/wat6.gif |
I buy my 12 points at Sears.
My local Sears did not have them. I asked and the guy said I wanted Torx bits. "No" I replied, I want 12 point. He still did not get it. It was not the best customer service.
Snap-on has them. You can get them on their web site. I flagged down both Mac and Snap-on trucks and they all said it is not a very common item to carry unless they have Porsche dealers on their route, or at least people who work on Pcars. As sombody else said, I think you can get them from Pelican.
The correct terminology is "tri-square" or XZN.
Online ontool sells the Stahlwille brand www.ontool.com motorhead sells Hazet www.motorhead.net hptools sells Stahlwille www.hptools.com There are others www.baumtools.com They all have a fair supply of Porsche related tools, if you don't need it right away. Or look in Pelicans tool area. Hazet also has a tool that accepts bits and is long and thin enough to do door hinges (actualy the tool is designed for VW's) www.hazet.com or www.hazet.de Also try www.themotoringshop.com the have a wobble socket that may work. And they are locatated around Wallyworld in Florida. Martin |
| All times are GMT -8. The time now is 01:00 AM. |
