Question SC Clutch Drag
A couple of months ago, I was lucky enough to adopt another Porsche (my first 911). My '83 SC clutch is possessed. If I push in the clutch while in gear, sometimes the clutch drags (lightly?). Sometimes it works fine.
If I'm stuck in traffic and I stop behind a car, the first time I push in the clutch it is usually fine. Then if I let out partly (to edge forward) and push in all the way again, I will usually feel it suddenly grab and drag a bit, until I pull it out of gear.
I adjusted the cable last night. Loosened the cable, backed off the adjusting nut to 1.2 mm from the release lever. Then tightened the cable until the release lever was about 1 mm from the adjusting nut. It looked fine, worked better when driving, but when I got home and checked for clearance, the release lever was sitting on the adjusting nut again. Went through the process over.
Even when the cable seems to be adjusted properly, I can feel the clutch suddenly grab if I'm stopped in gear. (Its fine for the first 10 seconds that I've stopped, then suddenly it catches.)
Am I a victim of the rubber centered clutch? (The car has 140k miles, though I don't specifically see a replaced clutch in the maintenance records, the tranny has been R/R'd and I'd hoped that the clutch had been replaced.) From the vehicle maintenance records, the clutch cable seems to have nearly 40k miles on it. Time for a new one again?
Old 04-10-2002, 01:02 PM
Senior Member
Superman's Avatar
How many miles on the car?
Mocha 1978 911SC. "Coco"
Old 04-10-2002, 02:00 PM
140,000 mystery miles. 40,000 miles on the current clutch cable. I think the same since the tranny was R/R'd.
Old 04-10-2002, 02:06 PM
rstoll's Avatar
I renewed the cable, clevis and pin on mine recently. Made a world of difference. Old cable was a little frayed.
Robert Stoll
83 911 SC
83 944
Old 04-10-2002, 02:34 PM
Better in Person
juanbenae's Avatar
i was told by a mechanic that if a rubber centered clutch went 30K it would have been hung on the wall as a trophy.
