jkeyzer's Avatar
Question MFI - warped throttle bodies - seek advice
Finally got around to working on the 911 a while this evening. Eurometrix advised putting a pane of glass against each individual throttle body to check for warpage causing air leaks. Well, I did it, and the bad news is that they are indeed warped. A PO (I plead innocent) most likely tightened them down too much and warped the flanges for each individual TB (one is even cracked). I very roughly measured the bowing to be 0.01" worst case, and it is visible to the naked eye upon close inspection of the flanges.
Seeking advice on a fix. Amateur machinist friend suggested sanding both TB banks against a known flat surface and if that fails milling them flat. Any potential pitfalls with milling away a small amount to make them flat? Cheap fix would be to use gasket goop but I am doubtful.
Thanks. I'll have this thing put back together someday.
Jeff Keyzer
72 914 w/2056 built by Mark DeBernardi @ Original Customs
Megasquirt with MSII upgrade
Old 04-09-2002, 01:39 AM
Warren Hall Student
Bobboloo's Avatar
Take them to a machine shop and get them resurfaced. I don't think it will cost much. They do this to heads all the time.
Also make sure they're good and clean before reinstalling.
Bobby
Old 04-09-2002, 01:46 AM
jkeyzer's Avatar
One more question, is this stuff weldable? I want to have the cracked flange filled in before machining.
Jeff Keyzer
Old 04-09-2002, 01:52 AM
Warren Hall Student
Bobboloo's Avatar
I would think so. They would just need to know what kind of metal it is. My guess is that it's magnesium but thats just a guess. I've heard of people welding the magnesium fan housings so it should be doable.
Bobby
Old 04-09-2002, 02:06 AM
jkeyzer's Avatar
Does anyone else know if these are magnesium or aluminum?
Jeff Keyzer
Old 04-09-2002, 03:08 PM
pwd72s's Avatar
Jeff, I've heard they can be either metal...but a good machinist should know by looking...color & weight.
Old 04-09-2002, 03:13 PM
jkeyzer's Avatar
Thanks guys. A friend has offered to do the work at no cost so I may take him up on it.
Otherwise if anyone knows of a good machine shop here in SD I will look into it. Kurt or Rich?
Jeff Keyzer
Old 04-09-2002, 03:53 PM
jkeyzer's Avatar
Turns out mine are indeed magnesium. Unless anyone has had success welding these, they appear not to be an alloy that can be welded.
I had everything resurfaced by a friend who ended up just using a flat machined surface and sandpaper. It turns out the plastic stacks were also not flat so I had him fix those as well. I think it's time for me to invest in an in-lb torque wrench and some new nylock nuts and washers. I know I've asked this before but does anyone have a torque spec for the TBs to heads and stacks to TBs? I can't find it here but I don't have the factory manuals.
Leaks between the TB and head may explain why #1 plug always seemed to look leaner than the rest.
Jeff Keyzer
Old 04-11-2002, 06:11 PM
