Help with wrench size needed for fuel line
Looking for help with the wrench size needed to replace a ruptured fuel line on my 88 Carrera.
-I ordered part # 911-356-066-08 from our host, can someone tell me what size wrench I need to remove and replace? Thanks in advance ![]()
Luke '88 Carrera ![]() |
MBruns for President
17mm and 19mm are all you need
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
Thank you Sir!
![]() ![]() On fuel lines its really best to use "Flare nut" wrenches whenever possible. They lock onto the nut and prevent slipping, especiall when pulling at a odd angle in a tight location. For the crossover hose between the Fuel Reg & Damper at the front of the motor, its so damned hard to get in there I have had to use a Flare Nut Crows foot ground down enough to clear the mounting bracket. Good luck w the job. Len ![]() |
