Condenser protector removal
What is the trick to removing the center bolt for the front condenser protection bar?
![]() This is the bar that wraps around the front lower AC condenser just behind the front lower spoiler. Maybe the bolt is removed from within the boot area? I can hardly see up there on my 930.
Thank you, HFR_Racer '87 930, 3.3 liter, K27 hybrid, Kokeln IC, Andial, B&B, Borla, 17" Supercups. |
open the hood and remove the bolt.
Thanks. Bolted from the inside then.. I've been busy blasting and painting suspension parts. Installing Elephant Racing bushings is my winter project.
