Cabriolet Electric Latch Fix 1 of 2 w/pics
I have had to do this about six times over the years with
different cars. So I logged it and took pics to possibly help others.
These motors are very simple but have very poor connection points that
can be fixed by anyone.
Sorry about 2 posts could not load pics into 1 post
Old 08-07-2011, 11:49 AM
I have a question, The passenger side Latch on my 89 has failed not the motor but the gears will not stop keeps rotating still works but I have to get just right. I will be getting a drivers side from a friend today that works, can I take the gear assembly from the new one and replace it with old one to make it work. Thanks and great thread
A man who dares to waste one hour of time has not discovered the value of life.......
Much Respect
Old 09-06-2011, 11:37 AM
Yes you can " But if your getting a new one today
why go the motion" or are you just testing with anew one.
Remember the washers that go under the gear they are planted with white grease and
can easily be missed. Just hit me back if you get stuck
Old 09-06-2011, 11:46 AM
I am getting a used one from a friend for free and it works fine so I think this will save me some $$$. I am glad to here that it will work I will follow your wright up Thanks..
Much Respect
Old 09-06-2011, 11:58 AM
Atlanta in-town
Have you seen incidences were the smaller brass colored gear has a fracture? I've seen two incidences of this.
I also had one that used a microswitch to stop the motor. It failed. It's good to have a donor unit handy if you're the diy type.
Old 01-29-2012, 02:20 PM
I had both of those problems, Yes it is good to have a donor available..
Much Respect
Old 01-30-2012, 03:54 PM
