-   -   camshaft timing specs for a 930/09 engine (http://forums.pelicanparts.com/porsche-911-technical-forum/65429-camshaft-timing-specs-930-09-engine.html)
Jadams1 04-11-2002 04:23 AM
I have a 1980 Euro 911SC with a 930/09 engine. The cams are maked with the 930 147.08 (left) and 930 148.08 (right). The Bently manual has the specs for 930/04, 930/07 and 930/16 engines. Anbody have the valve overlap adjustment specs for mine? Thank You.
John
epbrown 04-11-2002 04:54 AM
From "911 Performance Handbook"
Intake: Opens 7 BTDC, Closes 47 ABDC
Exhaust: Opens 49 BBDC, Closes 3 BTDC
Emanuel
PS: Sorry it took so long...;)
Jadams1 04-11-2002 06:00 AM
Emanuel, I was looking for the valve travel 360 degrees from TDC. Is it 1.55mm (0.061")?
john walker's workshop 04-11-2002 08:04 AM
1.4 to 1.7, so right between them is the suggested spec.
epbrown 04-11-2002 08:08 AM
I don't see that listed. I also checked <i>Porsche 911 Story</i> and don't see it there either. Sorry.
Emanuel
Jadams1 04-11-2002 08:37 AM
Thanks, for the replies! I wanted to check the cam timing before I tear down the motor on Saturday. Thanks again!
John
Jadams1 02-03-2004 05:53 AM
I accidently pasted this reply here, please disregard.
See if this link helps.
http://forums.pelicanparts.com/porsche-911-technical-forum/65429-camshaft-timing-specs-930-09-engine.html?highlight=cam
