racer_X's Avatar
Ground strap- copper or ?
Does anyone know what the battery ground strap is made of?
I am in the process of fixing the corrosion mess caused by an over charging battery in my 77 911.
I dropped the ground strap into some vinegar to let it soak over night. It is now a nice silver color, with some areas that are either rust or copper, I can't tell yet.
Anyone know the material?
John
1977 911S
Old 02-02-2012, 07:56 AM
porsher
aston@ultrasw.c's Avatar
It's copper wire, with plating/tinning.
TR8! woot
I built an MGB-GT V8
86 911 Race Car, with a few 993 bits in the boiler room
79 928 Race Car
88 928 Becoming a Race Car
Old 02-02-2012, 08:30 AM
racer_X's Avatar
Okay, so I shouldn't wait for it to turn copper color in the vinegar.
Yes the TR8 was rare and cheap and I couldn't pass it up, though I would love a MGB-GT V8, that is a very cool car.
John
1977 911S
Old 02-02-2012, 08:39 AM
porsher
Nope.
I took a 72 B pulled out the cast iron 4 and shoe horned in a 215 aluminum V8!
I used the motor out of an old Rover saloon, not the detuned Range Rover lump that the factory used.
79 928 Race Car
Old 02-02-2012, 08:45 AM
Mo money = mo parts
New ground straps are only $16 in the catalog. Honestly, a weak ground strap can cause way more than $16 in aggravation.
Greg
86 Coupe (stock - pretty much like Butzi designed it) - gone, but not forgotten
65 Ducati Monza 250 & 66 Monza Junior (project)
"if you are lucky enough to own a Porsche, you are lucky enough"
Old 02-02-2012, 10:54 AM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
And remember guys...the block or frame place where the cable will be connected MUST be clean...and shiney if it can be.
If in doubt as to whether the connection is clean or not...imagine licking it with your tongue!
You don't really lick it...but you get my drift....LOL
In electronics and electricity....cleanliness is ahead of the other part.
I have seen too many supposed connections that simply were not connected properly.
One of the quickest checks is to touch the connection after it has been turned on (flowing power) for a while...if it's warm or hot...it's a BAD connection!!
With power flow...resistance creates heat...bad for everything.
Bob
Bob Hutson
Old 02-02-2012, 11:01 AM
Bob
+1
After removing and cleaning all the major earth points on my 3.2 and re-fitting with new fixings and using copper slip on re-assembly the motor turns over so fast and effortless now wether hot or cold, before it always felt like it had a flat battery very embarrassing, especialy after filling up at the petrol station well worth the effort and time involved.
Anthony.
Old 02-02-2012, 11:17 AM
It's not a Porsche ground strap, just a ground strap that carries domestic current.
S
Old 02-02-2012, 11:56 AM
