Un Canadien Errant
aldente295's Avatar
DIY Engine Grill
A little while ago I picked up a ducktail for the half dozen or so track days I do each year. It didn't come with a grill, and I wasn't really prepared to buy one for the prices I was seeing them listed at. For awhile I just had some mesh covering the hole, but then I decided to see if I could build a DIY grill out of aluminum bar. I took a few photos along the way.
end of part 1...
Alan
1980 911SC - 'Brian'
Old 05-24-2013, 11:35 PM
Un Canadien Errant
aldente295's Avatar
end of part 2...
Alan
Old 05-24-2013, 11:45 PM
Un Canadien Errant
aldente295's Avatar
It's not gonna win any show and shine awards, but good enough for the race track!
Alan
Old 05-24-2013, 11:51 PM
The Dude abides...
bigel's Avatar
How much did you end up saving?
'03 Carrera 4S
Old 05-25-2013, 03:56 AM
300hp 1800lbs is the goal
pksystems's Avatar
subbed.... I have something similar planned
The '66 912 Bastardization project has begun.
Note to PO's: LAY OFF THE FREAKING BONDO!!!!
The science was settled: Earth was flat.
Galileo : Flat Earth denier.
Old 05-25-2013, 06:14 AM
Elombard's Avatar
Wow - that is amazing. I wonder what it would look like with out the mesh. Just add 20 hours of tweaking grinding and polishing and it would look factory! :-)
I wonder if I could do this with L instead of U channel? Might look OK. Very creative, I love it!
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 05-25-2013, 08:25 AM
1984 Carrera Coupe 3.2
Great work-and ability to think outside the box! Really nice to see projects that were accomplished without a lot of specialized tools and garage space-thanks for posting it!
Old 05-25-2013, 09:04 AM
very nice. good idea, and much more robust than factory.
Old 05-26-2013, 05:27 AM
Banned
Looks nice. I kinda like the mesh part. What kind of mesh is that, and where did you get it?
Old 05-26-2013, 09:34 AM
I think I used a similar mesh source as "aldente" -- Lowe's? Pardon the dusty tail from garage queening....
I double-folded at the front and rear edges to increase robustness -- but didn't put much effort in to alignment. I originally thought that it would not work well.
Old 05-26-2013, 12:05 PM
Un Canadien Errant
aldente295's Avatar
Mine is actually from an old electric heater that bit the dust, but there is similar mesh at our local FLAPS here in Oz.
Probably cost me about $60 or so.
The real improvement I would love to make but don't have a solution for its getting a better curve on the flat bar. It's not quite right - the curve should be more gentle rather than two bends on either end. But I didn't have a way that I could do that easily.
I considered the L channel, and it may work - but I must say I was happy with the additional strength of the U.
Alan
Old 05-29-2013, 05:19 AM
My mesh is the 4ft x 8ft reinforcing mesh, used in plaster work or in concrete work. It's about $5 for an entire large sheet.
Since it is steel, you must spray it well to prevent rusting. I think there may be an equivalent in aluminum somewhere.
Also used it on my nose grill.
Old 05-29-2013, 06:25 AM
4flyboy's Avatar
Mad skills!!!! Very inspiring....... Scott
Scott
"Houston, Tranquility Base here, the Eagle has landed"
Silver 1984 M491 Sunroof Coupe
Old 07-16-2013, 07:48 AM
