-   -   Show me your... a/c controls! (http://forums.pelicanparts.com/porsche-911-technical-forum/654671-show-me-your-c-controls.html)
tirwin 01-30-2012 05:06 PM
I'm in the middle of redoing my interior. I keep thinking about deleting the center console but I don't know what to do with the A/C controls.
Let's see your ideas! Show 'em if you got 'em!
86 911 Targa 01-30-2012 05:20 PM
Do a search-console.
clexton1 01-30-2012 05:23 PM
A/C Control
I did something a little different. Since I no longer had foglights and dont use the rear defrost, I used those holes for the fan and temp control for my A/C. Mine is a '76 so no center vent, just the one hose under the dash for A/C.
Paul
http://forums.pelicanparts.com/uploa...1327972786.jpg
timmy2 01-30-2012 05:39 PM
In the picture above there is a circular depression for a switch behind the wiper stalk on the dash. I have a rotary switch for cooling on the outside with a fan speed switch in the middle. (Like a stereo knob with volume and balance)
Here is a pic. (crappy one but you get the idea)
http://forums.pelicanparts.com/uploa...1327973939.jpg
timmy2 01-30-2012 05:48 PM
Better picture?
http://forums.pelicanparts.com/uploa...1327974496.jpg
tirwin 01-30-2012 07:02 PM
Timmy2,
That's a pretty slick idea!
Koizumi 01-30-2012 08:55 PM
Very cool (pun intended, too).
timmy2 01-30-2012 09:06 PM
Originally Posted by tirwin (Post 6527605)
Timmy2,
Can't claim it as my idea, car arrived in my driveway like that.
I believe it was dealer installed when it was imported into the US and resided in Arizona for a while.
Silver Rotary rheostat outside, 3 position speed switch (black) inside.
fred cook 01-31-2012 05:42 AM
Console delete
When I reworked the interior in my SC, I also wanted to delete the console. My solution was to make a panel that fit where the ashtray was located and mount the two a/c controls there. Here is a picture.
http://forums.pelicanparts.com/uploa...1328017114.jpg
The panel is made from a piece of sheet aluminum (available at your local Lowes) cut and bent to fit. The existing wires and tube were just long enough to fit. Hope this helps.
fred cook 01-31-2012 05:45 AM
Pcar upgrades.........
Tim,
Have you done any work on installing your fuse panel yet? Please send me a picture when it's done.
Fred C.
tirwin 02-18-2012 10:24 AM
Fred,
I haven't yet. That will be towards the end of the project. I'm also going to be installing a DRL module, a quick disconnect for the battery and running power for an amp so I figured I'd do all that stuff at the same time. I'll keep you posted!
tirwin 02-18-2012 10:31 AM
Fred, I think I'm going to do exactly what you did with the A/C controls. I just don't think I'm going to be happy with the interior if I can't get rid of the console.
Brown747 02-18-2012 11:47 AM
My 78 had the dealer installed controls between the seats just behind the console.
Thor
http://forums.pelicanparts.com/uploa...1329594265.jpg
tirwin 02-18-2012 01:04 PM
Thor, that's a good idea too! Hmmm... Wonder where one could find a box like that? I suppose fabrication is always an option.
I could do this OR Fred's idea. Either way, I'm going to fab something to replace the ashtray and add a mounting bracket from Pro Fit International to have a place to mount my phone.
