Austin Porsche Bill
Configuration of Pins on a Sealed Beam Headlight
Hi. I have a 1973.5 911T that I am trying to get back on the road. I broke both the headlight connectors a long time ago, so now I need to know the pin configuration. I am pretty sure from other non-Porsche forums that the horizontal blade on the headlight is most likely the low beam, but don;t have a clue which of the other blades is the high beam and ground.
Looking at the headlight housing, here's what I mean:
Low Beam
Can anyone help me decipipher which blade is which?
Thanks.
Old 01-29-2012, 07:02 PM
HarryD's Avatar
The top drawing at this web site gives you the data you seek: ECE 165mm Rectangular Headlamp Wiring Guide
Hi| | Ground
___
Low
This thread may be helpful too: Hella H4 SD Socket wiring
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 01-29-2012, 07:53 PM
Austin Porsche Bill
Thanks. All working now . . .
Old 01-31-2012, 07:08 AM
