Mo money = mo parts
Challenged by a new parking brake cable
My new parking brakes cables are installed minus one step. I am really struggling to get the cable end housing over the nipple on the firewall. I had to pry the old one off with a screwdriver, but I assumed that was on there a long time. I have tried sliding a wrench around the housing and tapping with a small hammer, but I'm afraid I will damage something. Anyone faced this issue and succeeded? BTDT Suggestions welcomed.
Greg
86 Coupe (stock - pretty much like Butzi designed it) - gone, but not forgotten
65 Ducati Monza 250 & 66 Monza Junior (project)
"if you are lucky enough to own a Porsche, you are lucky enough"
Old 02-11-2012, 10:58 AM
Mo money = mo parts
I got it. I slipped a 13mm open end wrench on it and hit the wrench with a hammer as close to the cable as possible. I should have measured and marked the point when it is fully seated, but didn't. I'm not worried, because it's on tight enough that it isn't coming off.
Greg
Old 02-11-2012, 11:58 AM
I have the exact same problem. I actually thought they were poorly made since I have repro ones, so I was releived to read your post. Thanks for the idea using a wrench!
Regards,
Johan
-14 Cayenne S Diesel, DD
-92 964 C2 convertible, RS -92 look and feel😃
-73 T US MFI Targa, restored
-70 T Coupé Hot Rod, painted waiting for assembly
-72 T Coupé, US numbers matching under restoration
Old 02-12-2012, 12:32 AM
