Thin flange or thick flange heat exchangers??
Hi,
I need to buy new heat exchangers on a budget. So I am looking for a set of used ones. Not sure what I need. Can anyone let me know? Thin or thick flange? I have an 82SC? I will then post a WTB add in the used parts forum... Thank you! Boris ![]()
Diss Member
Looks like thick flange to me but they are so rust I can't really see the corner of the flanges from the picture.
BTW - You can use thin flange exhaust on a thick flange car with the possible addition of some spacers/washers and cleaning up the threads. So if you see a killer deal don't let that stop you. Be very careful, using heat and penetrating lube, to pull them off. You don't want to snap a stud and mess up your day. Use copper nuts when you put them back on to future proof the install.
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
1982 is thick flange. I just removed mine and replaced with stainless steel exchangers. I am selling my old exchangers, if you are interested.
I have a set from an '81 I'd sell also.....
Bob S. 73.5 911T 1969 911T Coo' pay (one owner) 1960 Mercedes 190SL 1962 XKE Roadster (sold) - 13 motorcycles |
<insert witty title here>
Definitely thick. I found out the hard way mounting early thin flange exhaust on an 82 sc engine. I couldn't figure out why the barrel nuts wouldn't tighten without the hex head socket slipping out
CDN Redneck
Did the 84 3.2 Carrera come with thick flange HE's also? I have to pull them off to clean the leaked oil out of them and will have to replace the Barrel nuts and Lock nuts. I will be installing new oil tubes while they are off.
The HE part # is 930-211-029-00 (both sides are the same) Thanks
84 Carrera Coupe 3.2L Tea Tray Tail Black on Black |
Diss Member
Retired Member
I have thin flanges on my 3 litre. I've had no issues for 4 years.
80 911 SC sold 17 Tahoe 07 Z06 Corvette
our host sells SSI's and in the description for your car it says thick flange.
CDN Redneck
The 80s Carreras are thick flange. Replace the nuts with copper plated nuts. It should really be a requirement...
Thank You! I am making up a project list and want to get he right ones.
I just removed my thick flange exchangers last week. They are for sale if you are interested. I changed over to stainless.
Banned
So, I get that the SS ones are better due to longevity, but are there any other benefits to SS HEs?
RETIRED
Some of the posts are confusing SSIs which are equal length stainless versions of early dual outlet HEs....with Stainless versions of SC wrap around HEs that are single outlet.....just sayin'......
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Are you still looking for a pair? I have a set available.
I got a pair at the local PCA swap. Thanks everybody!
grateful user
you can use the thin flange if you want. Just use spacers or get nuts, or what i did, allen heads. (have to remove studs to use allens)
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do. |
