Toujours l' Audace
Fan air deflector 85-911
What happens if one when reinstalling the alternator on an 85 -911 does not install the winged deflector that is behind the fan and attached to the alternator.
Is that thing a vital part? Sounds dum I know but the thing is a &**&*^$#@!! to reinstall
mflo
porsche85
gmc 72
Old 02-01-2012, 05:37 PM
47silver's Avatar
need it
the deflector is required to make sure air gets to all cylinders without it, the air will take the path of least resistance and you will more than likely burn up a cylinder.
It should not be that hard to put it on? slip it over the wires, then wire it up
then bolt it on.
1975 911S Targa
Silver Anniversary Edition
Old 02-01-2012, 05:53 PM
Does the orientation matter? Sounds like if it wasn't clocked properly, it might not direct the air in the manner you suggest is important.
Ken
1986 930 2016 R1200RS
Old 02-01-2012, 06:02 PM
Yes the orientation matters. It's pretty obvious which way it goes. The cone is offset and the hole for the wires goes at the 6 o'clock position. The air deflectors blow the air toward the 123 side.
-Andy
Old 02-01-2012, 06:09 PM
Detached Member
Hugh R's Avatar
Ditto, what was said, very important.
Hugh
Old 02-01-2012, 06:23 PM
Toujours l' Audace
Thanks -sort of figured it was best to put it in --but not so easy-those old wires are rather short and stiff .
anyway got to keep at I guess --just don't like wrenchin like I used to
mFloi
porsche85
gmc 72
Old 02-01-2012, 06:36 PM
Detached Member
Hugh R's Avatar
Just a suggestion, try soldering on additional lengths of wiring of the same gauge, use shrink tube, not electrical tape. I did this for a few wires in my car. One of my biggest peeves about these cars is that they don't give you an extra inch or two of wiring to easily work on the things.
Hugh
Old 02-01-2012, 06:43 PM
cashman's Avatar
When I replaced my voltage regulator I had to dremel the deflector to make it fit. The new OEM replacement VR had a slightly thicker dimension. That may be the issue?
1989 911 Carrera Cab
25th Anniversary Edition
Euro Pre-Muffler, SW Chip
There's nothing better than: Listening to "Going Down the Road Feeling Bad" ,as I, "Go Down the Road Feeling Bad"
Old 02-01-2012, 07:54 PM
Toujours l' Audace
Thanks you correct about the wiring being shall we say scant
Mflo
porsche85
gmc 72
Old 02-02-2012, 06:44 AM
