adamnitti's Avatar
Send a message via AIM to adamnitti
Post What's better: Vacuum or Pressure bleeders?
Want to buy one of these so I can change my brake fluid by myself...
Adam Nitti
ajnitti@mindspring.com
www.adamnitti.com
'85 911 Carrera Coupe
PCA member, Peachstate region
Old 07-28-2001, 06:42 AM
Senior Member
Doug Zielke's Avatar
Post
Adam,
Take a look at the MP website:
http://www.motiveproducts.com/
This little outfit works as good as my friend's $600 Snap-On vac brake bleeder.
You can't go wrong for $44. You can order direct, or from Pelican, too.
(Not affiliated with MP, just a v. satisfied customer).
'81 SC Coupe (aka: "Blue Bomber")
Canada West Region PCA
The Blue Bomber's Website
Old 07-28-2001, 07:38 AM
Senior Member
Superman's Avatar
Post
I have a vacuum tool, and it works on brakes, and it works for testing other stuff...brake booster diaphrams, vacuum advances, sucks up liquids....
But I suspect that the pressure bleeders are a little better for brake bleeding.
'83 SC
Old 07-28-2001, 07:48 AM
Post
If you use the pressure type you will have to plug or crimp the vent hose on the resevoir closed to avoid pumping fluid out during pressure charging. I my opinion the pressure type is best. I've tried the suction type and they are less efficient since they suck air around the bleeder fittings threads during the bleeding process; it just takes longer to do the job with this type. An alternate that nobody has mentioned is replacing the bleeder fittings with the aftermarket fittings available that have a check valve built-in and thread sealer to elliminate leak-by; you just open the fitting and pump the brakes, that simple! Wonder if Pelican sells these, I saw them advertised in the Ecklers catalog (for Corvettes), the manufacturer makes them for most other popular applications as well.
[This message has been edited by movin (edited 07-28-2001).]
Old 07-28-2001, 09:18 AM
