cat converter question
I have a 1991 911. I don't have to have smog testing on this car locally.
Can I remove the cat converter and install a bypass pipe with a 02 sensor and the car still run well? Or will this affect the fuel mixture or other engine management systems and turn on the check engine light. Thanx! L |
Hi
cat bypass and o2 sensor install, the car should run well.
"A good sense of humor is the best thing to have in your toolbox when working on these cars." Quote by Charles Freeborn, Pelican. |
Spiderman
Also, you might like the "cleaner" look but be prepared for a bit more noise. Don't sell or discard the cat till you know you like the result overall.
I like the cat bypass pipe on my 87. Might also consider a "pre-muffler" vs bypass. My car is definately louder inside, no more talk radio with my hearing.
Midnight Blue 08 Cayman S, Fun/Track Black 12 VW-GTI, work Mexico Blue 87 Carrera, sold, sad, not enough garage space. |
Thanks guys.
