boxster03's Avatar
Anyone in the Seattle Area with a Paint Meter
Anyone close to Woodinville, WA 98072 with a paint meter they would be willing to check a car for me ?
Suppose to be original paint.
You can PM me.
Member #750 Early911S Registry
1970 911E
I know Where Jerry S. has his NYC Garage
Yadda Yadda Yadda
Old 02-10-2012, 01:04 PM
In my limited experience you can usually see if the paint is not original, look at different angles of light until you are seeing the orange peel pattern and not the color, take a close look the pattern should be exactly the same in adjacent areas e.g. rear panel to door or door to fender. If you have a friend that is a paint and body person there are many other things to look at to see if the sheet metal has been taken off or repainted. Not that using a paint meter is a bad idea. I got burned by this when I bought my car.
Sold: 1989 3.2 coupe, 112k miles
Old 02-10-2012, 02:07 PM
Banned
Ask for Blake - tell him Eric sent you.
NorthWest Auto Salon | Auto Detailing and Clear Bra in Seattle, WA
Old 02-10-2012, 02:12 PM
boxster03's Avatar
Thanks a lot guys !
1970 911E
Yadda Yadda Yadda
Old 02-10-2012, 02:43 PM
A visual inspection can't tell you the existing coating thickness (i.e. repaints) nor the amount of filler hidden under the paint. As I recall, new paint coatings from the factory are around 7 mils thick.
Sherwood
Old 02-10-2012, 04:17 PM
