Is this oil pressure low?
Test drove a 78 911sc yesterday and noticed the warm oil pressure was between 0 - 1 at idle, and around 2 when cruising around 2-3k rpm. The car has 190k but supposedly had the top end rebuild at 140k. Does that seem abnormally low?
Once warmed up and circulating, the oil pressure at speed should be around 4 at 4-5k.
At 2-3k, you are loafing the engine. Others may chime in here !
15 year PCA member ![]() 1972 911 E Coupe - gone now 1987 Mazda RX-7 2+2 - still cooking Swift DB-1 FF & Swift DB-3 F2000 -not forgotten 1979 911SC 3.0 & 2000 Camaro |
That is also my experience with a 79 SC I drove since new. Idle (ca. 900 RPM) pressure has always been somewhat below 1.
79 SC Targa 72 T Targa Sold 68 T Coupe Sold 65 912 Coupe Sold 62 356B Coupe Sold |
My 78sc shows 1.5 at idle (hot) and flicks immediately to 4.5 as soon as I hit the throttle. Also , annoyingly
, my oil level gauge reads midway when the oil's hot and car is level - just as the maker intended!You should get 1 bar pressure for each 1000rpm, as a rule of thumb. Also , the pressure sending unit must match the gauge. Suggest you rev to 5000 - and report back!
'81 924 , '85 944 , '78 911SC , '82 928 5.0L "They run best being run close to the ‘limit’ and done so regularly" - Grady |
Free minder
What weight oil are you using? Maybe it is too light for the outside temperature. High weight oil should give you higher pressure.
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/ 2014 Cayenne platinum edition 2008 Benz C300 (wife’s) 2010 Honda Civic LX (daughter’s) |
Flat Six
General rule of thumb is 10 psi per 1,000 rpm
Dale 1985 Carrera 3.2 -- SOLD 2026 Jaguar F-Pace / 2025 Ford Bronco Sport |
