Front fuse box cover - 87
Any tricks to removing the fuse box cover on the main front luggage compartment fuse box of an 87 Carrera? Seems like there's a clip in the bottom center that does not want to come loose.
Thanks. Ken
Old 02-12-2012, 01:40 PM
1986911's Avatar
Usually you just squeeze the cover and it pops off. I have the opposite problem, my cover pops off all the time. Check around to see if someone screwed the cover on.
MG---1986 911 TARGA, SSI'S, STEVE WONG CHIP, M&K EXHAUST, ELEPHANT RACING GOODIES + TRU DESIGN CUSTOM FUCHS
1989 930 FACTORY SLANT NOSE -- RARLYL8 EXHAUST, K27 7200, TIAL 46MM, 0.9 BAR SPRING, GARRETSON INTERCOOLER , LEASK WUR, WEGO IV AFM AND NHS BOOST GAUGE.
2012 DODGE RAM 3500 LONGHORN 4X4 "EVERYTHING BUT THE KITCHEN SINK"
Old 02-12-2012, 01:45 PM
Thanks for the reply. I put a mirror under there and saw that the center metal clip under the fuse box was a little bent. I was able to straighten it out and all is well.
Old 02-13-2012, 07:35 AM
push down and out on the top clips and rotate way until the bottom comes undone.
to install get the bottom clips in (feel/guide with fingers) and rotate up and clip in the top
Sold: 1989 3.2 coupe, 112k miles
Old 02-13-2012, 08:02 AM
