Senior Member
Side window wipe's installation
Ok guys, I have searched and searched and could not find the answer.
Car has been repainted and I am putting new rubber everywhere when installing the parts back on the body. Door is about together but cannot figure out how to put the rubber wipe that goes on the outside of the window on the piece. It appears that it slides in the aluminum piece but for the life of me cannot figure out how it comes off. Does it just pop off with a thin screwdriver or ??? Thx, Joe
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
88 911 cp
Yes, the metal strips have clips that just pop into holes in the top of the door. If you start at the back end of the strip it should pop up when you pry carefully.
88 Carrera 3.4 smile making fun mobile |
Senior Member
Thanks and just what I needed to know!
Joe
Senior Member
JC, worked like a charm!
Thanks!
