I have an '82 911SC. Are the valves self-adjusters or must they be done manually? How often? If so, what is the setting? Thanks, Lars in Boise
Vinyl guru ask 4 a quote
Pelican Technical Article: 911 Valve Adjustment Made Easy
or.... http://www.pelicanparts.com/techarticles/911_backside_valveadjust/911_backside_valveadjust.htm
1983 cab. 3,6 lots of other stuff. Now the daily driver. 2012 Mercedes ML 350 Parked. |
The Mighty Pieholio
993s are hydraulic. You will need to adjust your valves. It is a highly pleasurable DIY job on these cars. You will notice immediate improvement.
Do a search here Buy the tool (feeler gauge with extra blades) Watch the videos Buy Wayne's book Take your time
1988 Carrera Coupe |
The Mighty Pieholio
LOL @ 10 thumbs!
I swear...I am not an idiot....and someone besides me can vouch for that...but the first time..WOW!! took like 30 minutes to set one valve....and I had to redo it 30 minutes later! now its really simple....the learning curve is fast and steep.
Ed M 86' Coupe |
Banned
Agreed, and one of the keys to the learning curve is the factory +/- .002 factor of the .004 gap - with this firmly in mind, the struggle is much less (for me, I would adjust if under by .002 but would not adjust if over) . . .
so, is .004 the only size gauge you will need for all the valves? i bought the curved one off of pelican and i only have 1 blade of .004. do i need multiple blades for a valve adjustment or will the one do?
thanks! |
Rite of passage for a 911 DIY. If you cannot handle this task, don't work on your 911. Then you graduate when you can do a cam timing on a 911. That also means you have taken your engine out of the car.
Porsche 2005 GT3, 2006 997S Exotic: Ferrari F348TB Factory Challenge, Ferrari 328 GTS Disposable Car: BMW 530xiT, Audi A3S Two-wheel art: Ducati 907IE, Ducati 851 |
Although, the factory spec is .004 plus/minus .002, so there's a lot of slop allowed. How much slop anyone accepts is how much time they want to put in, and hoe flexible they are.
Mike Bradshaw 1980 911SC sunroof coupe, silver/black: The Wurster 2006 Mazda3 5 door, M-speed exhaust: The Ricer Putting the sick back into sycophant! |
good stuff, thanks much!
83 911 Production Cab #10
If you got only one, you will break it (bent out of shape) on the first few valves. If you got spare ones, the blade will last for a few Valve Adjustments...
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
so very true, they are cheap, so i tossed a few in my cart the other night since i need more parts anyhow.
Sorry to open such an old thread... A few days ago I performed a valve clearance adjust. Now engine only fires on cylinders 1 and 4. Other cylinders not firing at all. Theres any chance y did the process wrong like for example TDC on 4th cylinder???
Kind regard |
Pop the distributor cap and turn the engine so the rotor points to #1 and see what you have on #1. Then check the rest. Then there's the plug wire mix up trick.
Did you remove the plug wires at the rotor? #1 and #4 will fire even if you put the plug wires back on in reverse.
1982 911SC |
Thread Tools | |
Rate This Thread | |
Tags |
911sc , adjustment , valves |
