2nd of all - 2 wires poking out means you have the updated 2 hire cht - damn boy, move from florida and you lose all your sense! |
Oh man flamed again! I was pretty sure it was the two wire given that plug. Crawled underneath to trace the wire but couldn’t see it with the wheel on. Funny thing, when I went out to check the plug, it was pulled out on one side (i.e skiddy-wampas). So it was a good thing the thread got posted and I checked it in my drunken state.
As far as movin to Salt Lake, I moved as close to the Liquor Store as I could. ;) Jason (two-wire CHT 88 911 CAB) |
I can;t bust your chops local - so now have to do it long distance!
holy batman! I was like...wha? a thread from Clark Griswald? Gotta be at least a few years old! Good to see the pics are still working :)
Thank You Clark!
This is an Outstanding Post. I recently replaced my DME relay. Started and ran great for a week now when at cold idle and at stops my baby has rough idles and last night after a 20 minute drive, I started it it hunted (reved up and down) in idle. :-( PCA tech recommended I check out/replace TCH 1st, but I did the easier and 2nd recommendation DME relay. I guess with this thread it is going to be my weekend work of love. On that special tool, do you think if I thread the wire through the 5/8" spark plug socket and use a monkey wrench could do the trick or do you thinking the needle nose plyers will torque it enough? Thanks Again!!! |
No = you need a socket to snug it down properly.
BTW, I did a pre-inspection of the CHTS. It is the notrious Single Wire CHTS :( The plug definitely has two sets of connections and mine is a '85 :-) |
Draco,
Perhaps you have a friend with a 4" grinder, pay a shop a few bucks to do it, rent or buy a grinder. They can he had for $40 or so. Cheaper than the labor at a Porsche shop, plus you'll have a tool for future use. regards, Steve |
Could you post a pic of your CHTS Tool Mod??? |
Found a Pic of the Specialty Tool:
http://www.midwayautosupply.com/imag.../WIL-W1267.jpg $9.99 at http://www.midwayautosupply.com/p-31476-wilmar-oxygen-sensor-socket-w1267.aspx Only thing, it comes in 7/8" opening not in metric. Apparently, that is the universal size for most sensors i.e. oxygen etc... |
Well Gents and Ladies,
I did the replacement, well almost...:( Wholy Smokes Batman :eek:. It took me 2.5 hours but I need to advise on a few things: 1. Get or make the 14MM deep socket with slot for the CHTS wire, is a MUST! the needle nose method is just too difficult to manuvere and tighten the sensor to the cylinder head #3. The heat shield will cut into your forearm, not really bad but it will scrap the heck out of it. Also if you grind the socket make certain the slot is at least 1/2" (or double the width of the base of the new wire where it meets the CHTS) wide and ground all the way to the ratchet insert. It is the only way the wire will not interfere with the tightening of it to the cylinder head. Sand down the edges as not to cut into the new wire. Unfortunately, I did not grind enough so I will need to redo the procedure, I just hand tightened the sensor to the head. I did not want to drive my baby without a CHTS, so I temporarily settled with it hand tightened. She runs fine but I will feel much better when it is properly torqued contact (11lbs). 2. Caution, when you install the new rubber plug that holds the CHTS, Speed and Reference Mark Sensor, DO NOT PULL on the wires from underneath the car, it will break the heat worn plastic housing at the 3 plug holder housing, my reference mark sensor fell apart and I had to use rubber insulated (heat resistant) electrical tape to rebuild the housing area so it will sit properly on the "3 sensor plug holder" with the retaining clip. I discovered this while I was finishing up the install. To keep this from happening, I would recommend marking then disconnecting plugs, becareful it may be brittle for us older Pcars. Use a small flat head screw driver to pry the thin wire lock to release the plug from the sensors. 3. Get a Pick and Hook Tool set $7.00 at Autozone. It makes removal of the rubber plug that holds the 3 wired plug much easier. The plug at the #3 cylinder head comes off by hand. Oh yeah the new CHTS rubber plug is scored but not cut all the way through so cut them so the two other wires can slip on. You do not want to do this during your install procedure. Fishing the CHTS through the hole was quite easiy. I could actually reach in the engine compartment and gently pull it to the 3 plug holder housing. The new CHTS has anti seize loctite but Pelican sales recommended I use the copper loctite for a better and lasting connection for the CHTS. 4. There two sets of clamps that keep the 3 wires together/neat. One near the left side of the engine just right of the 3 plug holder housing and then one near the CHTS. 5. The original single wire CHTS is definitely a 13MM, I cut the wire at the CHTS but still too long for a standard 13MM socket. I suggest getting a 13MM deep socket $4.00. It was a Biotch to remove, locked tight probably due to age. Result: No more hunting after warmed up and driven on the freeway for 1/2 hour. Maintaining 800 RPMs at idle, no stall or dropping of idle at cold start :) Smooth Start, Idle and Steady Acceleration. I will feel much better after I tighten the CHTS after moding the 14MM Deep Socket. Thanks again CLARK I would have been totaly lost without this thread!!! |
hey folks,
thanks for this great thread! I am going to be putting it to use today while I change the CHT on my 3.2l 75s did the dme relay yesterday and put a SW chip in last week distrributor cap and rotor as well as plugs and wires done this summer new alternator in the spring so little by little everything is being freshened up and the results are very nice just getting better all the time |
ok.
I did mine and the one I replaced was the old style single plug type and it was a thirteen milimeter nut. my twin plug replacement uses a 14 mm nut but the threads into the cylinder head were identical so fit was no problem tightened with a needle nose pliers. very tight access and the grommets were a bit of a pain in the butt. I also managed not to tape the old to the new tightly enough and I had to push it through from the bottom instead.... lots of cursing under my breath:D the key on my car was held in place by two small screws. I didn't notice that in any of the descriptions, but I pulled on it for a few minutes before I noticed... lol and after everything went back together well. all in all I think replacing the dme relay was the most effective of the work done. not sure which i prefer now O2 sensor plugged in or not... still back to backing it. seems to pick up revs smoother with it unplugged, but with the o2 sensor plugged in it seems to be quicker over 4000 revs. so, SW chip new plugs and wires new distibutor cap and rotor new alternator new relay and new CHT sensor big test is starting on a very cold morning... will she or won't she? anything else I should look into on a near 100,000 mile 3.2 |
Great it worked out :D
Two Small Screws on the Key? Hmmm your pre '84 must be different. Glad you figured it out. Yeah, O2 Sensoris my next project, They only last 60K miles so if it has not been changed it may need it. So far I've Changed: DME Relay (Starting Issue) CHTS (Upgraded to Double Wired) ICV (Idle Hunting and Rough Idle at Stop) AAV (Dang Buzzing) O2S ( Pending, 160+ Miles, It's Time ) |
Well just to refresh this thread after 2 years. Decided to replace the CHT as I am replacing the reference and speed sensors. Thought about it for a few days " What about if I cut the wires and then cannot get the CHT sensor out?". Well that is just about what happened!! Should have trusted my instincts!! Cut the wire and then tried to back out the sensor, well after 26years you can imagine it was not going to be a ' piece of cake". Eventually it started to move but after a few turns it got stiffer, so WD-40'd it tightened it back in a bit and then backed it out, after it was out 5mm, it just kept spinning and would not go in or out!!. A few choice words like 'golly gosh!!' and ;'Oh bother' were heard. I managed to get a broad screwdriver around the back and into the gap between the Head and the CHT and as I started backing out the CHT a bit more I turned the screwdriver in the gap to help force the CHT out. It worked, although the threads on the CHT are stripped I think the threads in the head are OK but just need to be tapped to clean them out:mad:. It could have been worse!! Does anyone know what the thread specs are on this hole for the die size. Thanks all.
Phew! Just finished my own. This thread was invaluable as reference. I managed it without removing shock, just more awkward and takes longer - mine probably took 5 hours!
The new one is 14mm but same thread. I used a ring spanner and cut a gap out of the ring. I found the best way to screw the new one in was to turn the wire with the sensor (do not pull the wire up into the engine bay until the sensor is screwed in). Once it gets started it easy to finish with ring spanner. The rubber grommets were difficult to remove but went back in easily with washing up liquid as lubricant. Good job I went into it as I found a ton of other jobs that need doing now! :eek: Heater flapper boxes are shot, and the Dansk pre-silencer I fitted a few years back (and 02 sensor) are rusted to hell - not good quality at all. Time for beer....http://forums.pelicanparts.com/support/smileys/wat6.gif |
THIS IS A VERY GOOD TIP Thanks, Bob
Since the sensor wire is hard to reach behind the manifold, I used the old wire to pull the new one through the sheet metal and back to the topside. I taped the new one to the old as follows: http://www.pelicanparts.com/ultimate...lthroughsm.jpg |
Absolutely, but my advice is to do AFTER you have screwed the new sensor in.
My '88 single wire CHT sensor was rather rusty and original. The plastic at the connector end in the motor compartment just crumbled in my hands. I figured that the removal may be a little stubborn so I soaked the sensor with PBS Blaster overnight and made a slot on a deep 13mm socket. If I cut the wire and had problems I would have a non starting car. Sure enough the soaked CHT sensor would not budge, and the socket spun so before I rounded the rusty CHT off totally I started the car and let it heat up. Put the socket back on on off it came!
Putting the new two wire 14mm sensor in was impossible due the bigger diameter and interference from the engine tin surround. I had to grind some metal away to thread in the new sensor. Also took out the shock and used a string to pull back new connector end into the engine compartment. |
CHT Replaced with some pics
OK, so just to provide some more pics, I completed the CHT sensor replacement in about 2 hours including making the O2 type sensor 14mm removal socket. I also used the advice to tape the new wire to the old cut wire in order to pull it into the engine bay which worked very well. Using a 4 1/2" angle grinder I was able to cut the necessary slot perfectly (ok, nearly so...).
I first cut the wire off on the old sensor as close as I could and used a bit of PB Blaster first to give it a little more coaxing. Then, using a standard 6 point 14mm socket and a 8 inch wobble extension (seen in enclosed pics) http://forums.pelicanparts.com/uploa...1348945233.jpg + a 6 inch extension it was an easy day to remove the CHT from the side of the car with the tire removed (definitely easier this way). This is the socket without the CHT installed on cylinder #3. http://forums.pelicanparts.com/uploa...1348945169.jpg Then I removed the single wire rubber grommet that covers the CHT and the triple wire grommet that leads back into the engine bay. Following that, I had to cut two slots in the new triple rubber grommet (previously mentioned in the thread), and taped the old and new wires together to pull them up. Very easy to do. insert the new plug in the bracket below the heater blower motor (removed the large plastic hose to get better access as well). Finally it was time to push the single and triple rubber grommets into place. The latter, was the most difficult part of the entire adventure, as it's hard rubber and at a weird angle to get to from beneath the car, but easier than from the wheel well side. Job complete. Enjoy the pictures. http://forums.pelicanparts.com/uploa...1348945278.jpg |
| All times are GMT -8. The time now is 08:34 PM. |
