-   -   Want dyno run data of your engine (http://forums.pelicanparts.com/porsche-911-technical-forum/657961-want-dyno-run-data-your-engine.html)
1QuickS 02-13-2012 08:25 PM
I am working on an updated venturi selection chart that is similar to the Weber published chart (below) but that has data that is specifically adjusted for our flat six engines. The popularized "Bruce Anderson" formula has been around for decades and predates publication in his book; as such it is a good starting point for venturi selection. It is however only a guideline formula and actually selects main venturis which don't match OEM selections; for example the formula selects 30mm venturis for the 2.0 911S which was delivered with 32mm venturis. The attached chart correctly sizes 32mm venturis for the 2.0 911S engine with HP developed at 6600 RPM however it appears to be fairly aggressive in venturi selection for larger displacement engines.
I keep track of what good dyno reports I can get but would like to flesh out my updated chart with more good data. If I can get the following data from your dyno run for your carburetted engine then I can "tune" my chart accordingly. I will publish my updated chart on this forum for all to share/discuss.
I would like to get the following data from your dyno run(s):
  • engine displacement
  • RPM @ peak HP
  • main venturi size
Thank you in advance.
Paul Abbott
info@PerformanceOriented.com
http://forums.pelicanparts.com/uploa...1329193212.jpg
