911scdave's Avatar
Clutch Pressure plate
Hi All
Got my 915 gearbox back from the repairers today, i am going to marry up the engine and box back together this weekend, the one thing that I'm not sure of is that in my workshop manual it say's i should make up 3 spacers with 6mm cap hex bolts to screw into the thread in each of the 3 rivet heads on the pressure plate to relieve pressure on the 3 springs (Sachs pressure plate). But the rivet heads are not threaded so i think the pressure plate must of been fitted without this being done.
Any advice please.
Dave.
Old 02-16-2012, 01:10 PM
lonewolf's Avatar
Can't tell you how many times I've bolted a pplate to flywheel.
Never have used the hex bolts.
just don't bolt it down tight untill you marry tranny and eng together .
the disc must be able to move around so you don't have a problem with input shaft.
once together tighten pplate bolts that you can see through starter hole .turn over eng to make sure you get all 9 bolts.
Old 02-16-2012, 01:16 PM
that spacer thing was a factory manual suggestion for the 70/71 clutches only. don't know why because all that's needed is to pull the release arm toward the pressure plate and turn the t/o bearing 90 degrees with a screwdriver. yours just needs a pilot shaft through the p/plate and into the pilot bearing as you evenly tighten the 9 bolts. a trick is to snug up 3 evenly spaced bolts just enough to hold the disc and tap the pilot shaft sideways until it goes in and out easily. then tighten them all.
206 637 4071
Old 02-16-2012, 02:14 PM
Mo money = mo parts
Great tip - should reduce friction.
Greg
86 Coupe (stock - pretty much like Butzi designed it) - gone, but not forgotten
65 Ducati Monza 250 & 66 Monza Junior (project)
"if you are lucky enough to own a Porsche, you are lucky enough"
Old 02-16-2012, 02:17 PM
911scdave's Avatar
Many thanks for the replys and understand what you have said. looking forward now to the weekend to get my hands dirty.
Cheers Dave
Old 02-17-2012, 11:43 AM
