EMJ EMJ is online now
Shock Replacement Advice for a 3.2
My 88 3.2 is showing its 190k on the clock every time I go over a bump - very rough ride. The car has 17" Cups and I've never changed the shocks or bushings since I've had the car the past 7 years, though the tie rods were changed when I first got the car. I believe the shocks are originals.
I'm looking for a smooth ride. Don't need Lincoln-Town-Car smooth, but smooth. I've done some research here via the search button and am thinking with starting out with front shock replacement (Bilsteins), then new spring plate and control-arm bushings. Will I see a significant difference with just the front shocks? In other cars I'd say it's an obvious yes, but not sure with the P-car. My inclination is yes.
Thanks!
Ed
88 911 Carrera Coupe
Old 02-16-2012, 01:40 PM
If you currently have Bilsteins, you can actually send them back for a rebuild, if I am not mistaken.
Not expensive at all.
Christopher Mahalick
1984 911 Targa, 1974 Lotus Europa TCS
2001 BMW 530i(5spd!), Ducati 900 SS/SP
2006 Kawasaki Ninja 250, 2015 Yamaha R3
1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750
Old 02-16-2012, 01:45 PM
gtc gtc is offline
abides.
gtc's Avatar
Do both ends at the same time. When you hit a bump with the front wheels, the rear shocks absorb some of the impact as well.
A set of neatrix (rubber) a-arm and spring plate bushings will only set you back about $100.
Here's the bilstein service page (if you have Bilsteins).
http://www.bilsteinus.com/products/search-service/service.html
Graham
1984 Carrera Targa
Old 02-16-2012, 01:50 PM
Rescuer of old cars
Arne2's Avatar
My '84 3.2 came from the factory with Bilsteins (shown on the windows sticker as "SPORT SHOCK ABSORBERS"). After 155k, they are still original and deliver what I consider to be an acceptable ride. Is it "smooth" by your definition? I don't know. I'd call it firm and controlled, but not harsh.
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 02-16-2012, 01:58 PM
I'd replace the front suspension bushings first. After that many miles and years, odds are you're metal to metal with your front A arms. Check your shocks and get them revalved if need be.
2007 Cayman
1986 Carrera coupe (sold)
1979 911 SC targa (sold)
Old 02-16-2012, 04:23 PM
