1967 911R Fuchs alloy question
I have a rear pair of date coded, 1967 911R Fuchs alloys, in great shape. I know they are expensive, but would anyone have any idea what they might really be worth? or where one may find such information? I tried ebay comparison, but no one has sold any for some time.
(I would consider selling) Thank you -Matt 801-603-4130 |
Minimum $1500 each. Post some pics including the profile of the wheel where the tyre sits.
There should be no part number cast into the wheel but if you look closely there will be an ink stamped part number on the back side of the wheel. andy |
Thank you for your reply! i will get some closeup photos of the wheels, and post them this weekend, as the wheels are stored a few hrs away from my current location. I will also locate and photograph the ink stamped part number, and post that as well.
Thank you! -Matt |
The part number might be inked in red or black. The date code is stamped down in the lugs. If it is a 67 date stamp, it will probably be pretty late in the year.
There is a lot of action (relatively speaking) over on the www.early911sregistry.org regards, Eric |
are the 911R fuchs the same as 911S 15x4.5" fuchs?
i have a set of 5 and trying to see what i'm going to do with them. |
No, R Fuchs are 7 inches wide with a special backspacing that has most of that extra width on the inside to clear the normal fenders.
thanks for the clarification :)
| All times are GMT -8. The time now is 12:25 AM. |
