Shakenbake's Avatar
Tie rod update & alignment
Well I just got back from getting the front end aligned and what an ordeal to get there. I shopped around and found a garage that does nothing but alignments (since 1945) and they said "bring her on in, we'll do it while you wait" These guys were top notch. I felt good pulling my screeching tires into the parking lot and seeing an old perfectly restored Mercedes Convertible (Circa 50s-early 60s) sitting there after getting an alignment along with several Corvettes an old T-Bird etc. It was a little more expensive than I expected but I didn't mind a bit ($70.00) for the piece of mind I left with.
"That Por-shee drives like a dream", so said the mechanic after returning from a test drive to insure everything was working correctly.
Well it's 89 degrees here in the Queen City, time to put the sunroof back and go for a long drive....Thanks to Craig Stevens on this board for his help!
Shakenbake (Chris Baker)
Need new toys
2001 VW Jetta VR6
2003 Sea Ray 200 Bow rider
Old 04-16-2002, 12:50 PM
Ever jump a Porsche?....
78targa's Avatar
Hey! A fellow NCer. Where did you go to get your alignment done? Believe it or not I have mine in right now awaiting a corner balance/alignment in a shop in Matthews (Sporstcar Authority). I would appreciate any good local P-car information. Too much West coast stuff here that I can't make use of. So far I have been pretty pleased with the place. The owner is heavy into SCCA and currently running in the trans-am series. More than willing to let me in the back to help work on the car.
Casey
Road-rally, Targa Newfoundland junkie!!!
1969 RSR 3.4L PCA class GT-3 (in progress)...1800 lbs and dropping
Thinking of driving in TARGA NEWFOUNDLAND? Contact me and I can help answer your questions. The event is awesome!
Old 04-16-2002, 06:42 PM
Shakenbake's Avatar
Casey, the shop I found is an alignment shop only. It is located downtown Charlotte on South Tryon, Carroll Aligning. Top notch outfit all modern equipment. Established in 1945.
Chris
Need new toys
2001 VW Jetta VR6
Old 04-17-2002, 07:59 AM
