Anyone have a schematic for the vacuum lines on a Carrera 3.2?
My has car has been so modified for the turbo system, I don't know sometimes if things are in the right place.
Yes! Thanks!
Hi FatSix, do you also happen to have a vacuum shematic for a 79 SC?
Vaccum Lines.
Here's a few more for the 3.2.
http://forums.pelicanparts.com/uploa...1329435568.jpg http://forums.pelicanparts.com/uploa...1329435726.jpg |
What is that switch behind the throttle body with 2 ports?
I forgot. |
Thanks for the links, FlatSix!
That is the temperature switch in Flat Six's decal.
The micro switch behind that in the photo that 86 911 Targa uploaded is the idle micro switch. |
I'm asking about the switch/sensor that has the two vacuum lines in that picture.
It's left of the idle microswitch in that pic. |
Gotta stop looking at pics on my iPhone, no zoom capability on Pelican. I see it's a temperature switch.
What exactly does it do? |
Vaccum Switch.
(NLA). http://forums.pelicanparts.com/uploa...1329437492.jpg |
Ah, I see what it does according to "Flat 6's" pic.
It is "T"d to the intake vacuum port on one side and then an outlet port to the oil tank. It must cut vacuum to the oil tank until the engine is warm I assume? |
bringing this back to life - trying to confirm what the temperature vacuum switch controls when hot. It appears to have one hose the goes from the switch back to the throttle body/intake - the other appears to go from the switch to the vacuum switch over by the oil tank. Is this correct? Earlier post claims it controls the fuel regulator and fuel damper - but my 85 3.2 is not set up that way - want to make sure all my lines are going to the correct place as I am hunting down vacuum leaks contributing to cold start issues.
Anyone happen to have a good couple of pics of the backside of a 3.2 to capture the routing of the vacuum lines? Those pics are helpful Gerry, just looking for a few more for detail.
Hi Guys, new here
Can someone post the other end of this tube?? I can figure out where it goes! http://forums.pelicanparts.com/uploa...1633724767.jpg |
Hi Nader2- That appears to be Part #30, which ends at the Recirculating Air Valve (#93020722702) located next to the oil fill cap.
http://forums.pelicanparts.com/uploa...1633726918.jpg Hope this helps! |
I've been search but can't seem to find what the part # is for 24A is in the pic. Can it be purchased separately? The rubber section on mine has a crack and I can probably repair it pretty easily, but wondered if it can be purchased.
Hi 88911Coupe-That's 93011032805, which is available from our host... https://www.pelicanparts.com/More_Info/93011032805.htm?pn=930-110-328-05-M100 Hope this helps! |
| All times are GMT -8. The time now is 11:51 AM. |
