-   -   If I lower the front end on an early 911 will it change my alignment? (http://forums.pelicanparts.com/porsche-911-technical-forum/65874-if-i-lower-front-end-early-911-will-change-my-alignment.html)
J.HK 04-17-2002 08:43 AM
I'm considering lowering the front end on my 911 to European specs and wondering if it will change my alignment.
The rear of my car already seems pretty low, so I'm thinking I just need to adjust the front. Any thoughts here??
Thanks,
j
stlrj 04-17-2002 08:57 AM
Lowering the front will cause it to toe out, increase negative camber and reduce caster.
Cheers
Joe
john walker's workshop 04-17-2002 09:11 AM
actually it toes in when lowered. the downward angle of the tierods straightens out as the car is lowered, pushing the wheels out at the rear.
