Introduction to my project
Hi everyone,
Since I have been admiring all the projects on this site for a while now I thought I would share what I've been up to. I got the car well over a year ago and had no clue where to start. I'm still lost but have decided to continue on working toward my ever changing mental image of what i want the car to be when its done. So far I have stripped the car to bare metal and had it epoxy primed. Collected full sc suspension then media blasted and powder coated everything (looks great), rebuilt carrera brakes, raised spindles to allow for 16" wheels and much more. Now I'm in the process of repairing all the rust and welding flares as well as installing a new horse shoe pan. I will add more pictures as progress continues. http://forums.pelicanparts.com/uploa...1329525933.jpg http://forums.pelicanparts.com/uploa...1329525977.jpg http://forums.pelicanparts.com/uploa...1329526009.jpg http://forums.pelicanparts.com/uploa...1329526098.jpg http://forums.pelicanparts.com/uploa...1329526140.jpg http://forums.pelicanparts.com/uploa...1329526192.jpg http://forums.pelicanparts.com/uploa...1329526238.jpg http://forums.pelicanparts.com/uploa...1329526269.jpg http://forums.pelicanparts.com/uploa...1329526294.jpg |
Nice looking project. Wow - it's a crazy amount of work to get it stripped down to a shell.
What year did it start out as, and what else do you plan on doing? |
It started life as a 70T. My goal to is to end up as a lightweight hot rod, not really following any specific model constraints just what I think is cool. I have a 2.4 and a 901 to put in for now.
Good start on the project.....................keep posting.
regards, al |
Welcome aboard oldgunner. You have made tons more progress than I have on mine. Still trying to get it to bare metal. Good job! Keep it up.
http://forums.pelicanparts.com/porsche-911-technical-forum/641618-other-woman.html |
Jealous! I wish I would have started with a bare shell. Lightweight Hotrod? Sounds like my kind of car:D Sub'd.
One place to start is by asking yourself, what kind of additional bracing, stitch welding etc do I need/want/desire now while everything is accessible....but maybe none at all! I just simple seam welded the laterals up front and added a strut bar from TRE. This would be the extreme...Quasi ST This is just plain cool --> Fraise ST built by TRE |
stiffen that puppy up while you have it stripped bare - Dave @ TRE has done this & posted about it on here
I will be stiffening the tub soon. The two links referenced by Combatic have given me lots of work to do. They are two beautiful cars.
Nice Shop!!!
Welcome to the jungle!....Off to a great start. Don't loose the mojo. These projects take time,patience, and $$$$$$$$$$$$. Sounds like you have a realalistic goal in mind, and will be a Killer car when you get it done. Thanks for the look, and keep us all posted.
KT |
http://forums.pelicanparts.com/uploa...1330037676.jpg
More pics of tasks that have been completed. http://forums.pelicanparts.com/uploa...1330037795.jpg http://forums.pelicanparts.com/uploa...1330037835.jpg http://forums.pelicanparts.com/uploa...1330037870.jpg Jigs completed for install of suspension pan.http://forums.pelicanparts.com/uploa...1330037943.jpg http://forums.pelicanparts.com/uploa...1330037970.jpg http://forums.pelicanparts.com/uploa...1330038041.jpg http://forums.pelicanparts.com/uploa...1330038113.jpg http://forums.pelicanparts.com/uploa...1330038141.jpg http://forums.pelicanparts.com/uploa...1330038167.jpg Just finished today. |
How much do you think a bare shell weighs? Appears you're able to spin this one around pretty freely....
Todd |
You are well on your way! Welding up your the heater vents and gas tank hole in the fender? Now we know you are serious =) What did you coat your small part with? (hubs, steering rack, bracks etc )
I powder coated all the parts battle ship gray this summer. I wasn't sure if baking the rack was a good idea or not so I tried it. It still turns smoothly by hand so I'm thinking its ok, time will tell.
I ran out of wire today or I would have finished welding up the block off panels. |
http://forums.pelicanparts.com/uploa...1331347508.jpg
http://forums.pelicanparts.com/uploa...1331347538.jpg Trying to determine the location of supports.http://forums.pelicanparts.com/uploa...1331347595.jpg http://forums.pelicanparts.com/uploa...1331347622.jpg http://forums.pelicanparts.com/uploa...1331347657.jpg http://forums.pelicanparts.com/uploa...1331347687.jpg starting the time consuming process of templatinghttp://forums.pelicanparts.com/uploa...1331347742.jpg http://forums.pelicanparts.com/uploa...1331347795.jpg http://forums.pelicanparts.com/uploa...1331347834.jpg I decided to remove the center support rail. Instead I will use a piece of aluminum and roll some beads into it for rigidity.http://forums.pelicanparts.com/uploa...1331347939.jpg |
updates
Still working.
http://forums.pelicanparts.com/uploa...1339629096.jpg http://forums.pelicanparts.com/uploa...1339629121.jpg http://forums.pelicanparts.com/uploa...1339629144.jpg http://forums.pelicanparts.com/uploa...1339629176.jpg All stripped and Powder coated. http://forums.pelicanparts.com/uploa...1339629202.jpg http://forums.pelicanparts.com/uploa...1339629225.jpg |
Very cool project - thanks for sharing! Not a bad time to raise your spindles if you envision a lowered front end.
The rear shock crossmember lookspretty pitted. Will you evenutally replace? Doug |
flares
Just finished adding the flares and got them ground down late this week. I also flared the steel rear bumpers to match and will take some better pictures soon. http://forums.pelicanparts.com/uploa...1346555741.jpg
Nice work. Having that great facility really helps, I'm sure. The 1970 tube looks like a rust free start.
Keep the pics coming. |
Progress report
Since the last time I posted any pics I have managed to borrow a friends JDsquared tubing bender and experience to put in the roll bar. It took about a day with lots of help but the finished product turned out really nice. The rear parcel shelf is finished and the tub has been stitch welded front to back.
Pan is also completed, fuchs have been redone and all bearings are packed set in place. Now I'm working on the panel fit as you can see. Any color suggestions are welcomed. My top choices right now are Slate gray, olive, and leaf green. I'll try to get some more pictures of the bright work that I'm polishing http://forums.pelicanparts.com/uploa...1361498678.jpg http://forums.pelicanparts.com/uploa...1361498700.jpg |
I like your color choices. There is a grey blue that is really nice, too. An old VW color. Sorry, don't know the proper name for it. definitely an old school color like you've already mentioned.
Doug |
Subd. Lookin great
Looks like a good tub to start with this project,getting harder to find,afterall rust never sleeps:(:(,good luck with it.
paint
My new favorite color...freakin love it.
The color is fantastic!
regards, |
Nice project. Looking great!
Paint
What do you think of the color? It appears much darker in person.http://forums.pelicanparts.com/uploa...1374017657.jpg
http://forums.pelicanparts.com/uploa...1374017680.jpg http://forums.pelicanparts.com/uploa...1374017702.jpg http://forums.pelicanparts.com/uploa...1374017720.jpg |
looking sharp! cant wait to see more
outstanding! very subscribed to this one :)
polishing
Now that the anodizing has been stripped its time to begin polishing and polishing, you get the idea. I started using a sander with 400 grit paper to remove the largest scratches, then moved to 400, 600, 800 by hand and then to the buffer. Many hours later the gaskets have been replaced and the frames are reassembled.
http://forums.pelicanparts.com/uploa...1374116055.jpg http://forums.pelicanparts.com/uploa...1374116078.jpg http://forums.pelicanparts.com/uploa...1374116100.jpg http://forums.pelicanparts.com/uploa...1374116126.jpg http://forums.pelicanparts.com/uploa...1374116146.jpg http://forums.pelicanparts.com/uploa...1374116172.jpg http://forums.pelicanparts.com/uploa...1374116208.jpg |
Wow. How am I just finding this now? Looks great and can't wait to see it finished.
| All times are GMT -8. The time now is 05:17 AM. |
