-   -   '81 3.0 rev limiter (http://forums.pelicanparts.com/porsche-911-technical-forum/659699-81-3-0-rev-limiter.html)
JT 02-20-2012 06:03 PM
'81 3.0 rev limiter
I’ve searched, but can’t find anything about the 3.0 fuel pump shutoff rev limiter. I have a 3.0 in my ’74 911 and the rev limiter was not connected. I need one as I track the car, but don’t know how to wire the fuel shutoff. I would get a rev limiter rotor, but they seem to be only available for the 2.7. Any suggestions other than a MSD?
Joe Bob 02-20-2012 09:54 PM
Euro models had it in the rotor.....buy one of those.
MSD makes a replacement CDI with a limiter. Lot's chepaer to use the rotor.
JT 02-21-2012 06:04 AM
Joe Bob,
Where do I get a rotor limiter? Pelican and others only shows them for a 74 to 77. Mine is an 81.
JT
Dan J 02-21-2012 06:08 AM
930 602 901 02
Joe Bob 02-21-2012 06:10 AM
I think that's the number posted above....call them and ask for Glen Sager. He'll set you up. Been awhile since I had my euro motor....they have different limits and they are engraved on the rotor.
JT 02-21-2012 06:14 AM
Thanks guys. I'll let you know what I find.
Dodge Man 02-21-2012 07:30 AM
Euro vs Turbo Rotor
As long as you are not running a CAT, the Turbo or Euro distributor rotor is the way to go. I have a 3.0 Euro in my 73. Decide the cut-off RPM you want. If I recall correctly, the Turbo is 7000 RPM and the Euro is 6800 RPM. The Turbo may be less expensive.
JT 02-21-2012 09:06 AM
Yeah, the Turbo is less than half the Euro and since it's merely a fail-safe device, I'll probably go with the Turbo.
