rear spoiler
Can the factory rear spoiler on SC's and Carreras be easily removed? Probably a dumb question, I know. I'm a prospective first-time 911 buyer and I just wanted to confirm that the spoiler is not a factor in choosing the right car (my wife, who will be sharing the car with me, hates the things).
Thanks!
Old 02-22-2012, 08:54 AM
Dublinoh's Avatar
You can remove them but depending on the design, you may have some holes to fill and then repaint rear deck lid. Or replace the entire rear deck lid. These come up for sale in the used parts classified section of this site fairly often for several hundred dollars. A popular modification is to replace the rear deck lid with a fiberglass "duck Tail" spoiler, maybe the wifey would like those better. Good luck with your search.
Old 02-22-2012, 09:02 AM
Sure, just get a complete spoiler & deck lid & a plain deck lid, I have a regular lid, Statton Duck Tail, factory Carrera Tail, factory Turbo Tail & 3.8 tail for my 78 SC, all mounted on lids so I can change as I see fit (I do the same thing with wheels)
Old 02-22-2012, 09:18 AM
Fleabit peanut monkey
Bob Kontak's Avatar
This would be the smartest route if she hates the tail. Pull the tail and lid off as a unit. Stuff it in storage and get another used one and paint it to match or search for one the same color that is in good shape. Make sure you get the original grill and condenser hardware. Whatever you do have it ready cosmetically before mounting. Easier hassle wise if you can get to the bottom side easily for painting, etc.
Note, I don't remember if the condenser hardware is the same if someone adds a Carrera tail.
Also, the ones with tails usually have two shocks vs. just one with lid only. Not sure if you can use two shocks with lid only.
Old 02-22-2012, 09:27 AM
I would like to lift the whale tail on the left side so that I can fix the rubber gasket....it's out of shape on that side for reasons unknown.
Do I have to remove all bolts and unhook the condensor to lift one side of the tail? Not wanting to do anymore wrenching than I absolutely have to.
Thanks,
Russ
Old 02-22-2012, 09:49 AM
Rescuer of old cars
Arne2's Avatar
You can, as the PO who removed my car's tail left both shocks in place. But the engine lid opens like a jack-in-the-box or ejection seat when the release is pulled if you have both shocks in place. I removed one of mine, much happier now.
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 02-22-2012, 10:17 AM
Banned
That gives an awesome mental image. LOL.
Old 02-22-2012, 11:25 AM
