Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > Porsche 911 Technical Forum
2.7 case rebuild
I have a 1976 911s 2.7 with 216,000 miles with the engine undergoing a rebuild and have just been told that the case is too tired. We have tried helicoils, then case savers and the head bolts are still pulling out. Because there was only one head bolt initially pulled, I have invested a substantial amount of $ on everything but the case. Now the foundation is discovered to be bad to the bone. The body of the car is in excellent shape so I would like to save the considerable investment that i have already made but decent 2.7 cases are hard to find. Can anyone recommend a machine shop that could find me a used 2.7 case, inspect it and install the case savers so that i can rebuild the engine on a proper foundation? Thanks for your thoughts.
Old 02-21-2012, 05:46 PM
Ollie's Engineering in Lake Havasu Arizona is real good with magnesium cases, however; I don't know if they could source a 2.7 case. For that you could post a WTB on the Used Parts Classified Forum.
Dave
'75 911s Coupe
Old 02-21-2012, 05:58 PM
The most ideal case for your use would be a case from a 73.5 T because the 2.4 never ran hot or stretched studs and the case tend to open up easily to a 2.7. The 73.5 are all 7R strength cases.
Bruce
Old 02-22-2012, 01:59 AM
Or you could just avoid 90% of the problems and go with a later aluminum block. If you no longer have matching number , who cares.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 02-22-2012, 04:35 AM
moneymanager's Avatar
Talk to Competition Engineering as well. They are certainly one of the best two/three shops in the country. But if I were doing my 2.7 over, and I went thru everything you did, I'd do a 3 liter aluminum block. Second best is the 73 7R case from the 2.4.
jhtaylor
santa barbara
74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's.
73 Targa (gone but not forgotten)
Old 02-22-2012, 06:35 AM
Chain fence eating turbo
I was going to say the same thing.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR P & C's, soon to be 993SS cams and GSXR 750 ITB's fed by 964 intake, Borg-Warner S366 turbo @ 1.4 bar, Treadstone full bay IC, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MegaSquirt 2 (v3.57 board) w/EDIS, Tramont wheels (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 02-22-2012, 07:39 AM
Kraftwerk's Avatar
Just chiming in here... What is the advantage of a 2.7 over a bored 3.0, is it lighter?
Aren't there two different types of 2.7 engines ?
jt
'83 SC
'96 M3
'99 MX-5
7 bicycles and a Metro Card...
Old 02-22-2012, 09:01 AM
bassfishman's Avatar
Call Ollie's they are experts with 2.7 cases. They most likely can fix it where others can not
1976 Targa 911S 2.7
Yellow
Old 02-22-2012, 09:32 AM
This isn't the for sale section, but I just pulled apart a good 2.7 case with no pulled head studs. PM me if interested.
Regards,
Chuck
Old 02-22-2012, 09:44 AM
Tags
2.7 , case , engine rebuild , machine shop
