you see Arthur...
jasonlee's Avatar
water inside
I have done some searching, and have looked at all the usual places where water can leak into our beloved 911, to no avail. Now after leaving my car for a couple of weeks, no water on the floor, I took it for a drive and found standing water in the rear foot well and from foot well, driver side only. Is it possible that this water is coming from underneath those areas while driving. I am at a loss. Any insight would be greatly appreciated.
J
82 911 SC, Cat bypass, Flowmaster 1 in 2 out lightweight flywheel and backdated heat
06 Cayenne S
00 ML 55 AMG
Santa Cruz Bullit
Old 02-21-2012, 10:21 AM
J,
If your car is a targa, this could be very easy to explain...
M...
'84 Carrera Targa (3.0 with SSIs, Webers, DC-19 Cams, MSD) - Sold
Old 02-21-2012, 10:34 AM
you see Arthur...
jasonlee's Avatar
nope its a coupe
J
06 Cayenne S
00 ML 55 AMG
Santa Cruz Bullit
Old 02-21-2012, 10:38 AM
Do you have a sunroof? Are the windshield and rear window seals in good shape? Door frame and window frame seals intact?
Old 02-21-2012, 11:05 AM
'82 SC TL
canamfan's Avatar
Check your drain tube(s) from the HVAC & main blower encasement in trunk (especiallly the one that has the grill to let fresh air in), it should go out to bottom.
76'S 1st Porsche white/can/can early rebuild (boo)
'84 Carrera cpe. all blk & stock 340k never a let down (might have been the best1)
'87 Carrera cpe white/blue short flirt
'89 Anniv. sil/linen very pretty miss her
'88 928S4 5spd. blu/blu cmplt.SS exh.chipped lowered
Old 02-21-2012, 11:09 AM
Probably from rear window rubber. Or take your carpets out and inspect your floor. Are any of the acce ss holes in the bottom pushed up? Is your from cover under the steering rack in place?
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 02-21-2012, 11:12 AM
schumicat's Avatar
it is probably related to sunroof or rear window seal. very unlikely coming in from below unless you are driving through flooded streets or something. I would take out the rear seats, shelf and carpeting and hose down the back area. you will probably see a little river coming in from bottom corner of window, pooling on rear seat well, and down to floor.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 02-21-2012, 11:13 AM
'82 SC TL
canamfan's Avatar
For REAR footwell leakage, check that the sunroof drain tubes (the ones tucked way back in roof, one on each side) are clear from debris
Old 02-21-2012, 11:16 AM
FPB111's Avatar
Put some paper towels under the rear seat cushion, press down, and see if they soak up some water. If the rear window seal is leaking at the corner water can puddle in the cushion well and run down to the floor when you start to drive.
2013 991.1 Carrera S Cab
2004 996 Turbo CAB X50 sold
2003 996 cab 6 speed Sold
1972 RS 3.2 twin plug short stroke crank fire, roll bar, sold
DE instructor since 1985
you see Arthur...
jasonlee's Avatar
if it is the rear seal, can I have it resealed, or do i need to replace?
J
06 Cayenne S
00 ML 55 AMG
Santa Cruz Bullit
Old 02-21-2012, 11:21 AM
dshepp806's Avatar
I'd replace the seal...I've the same (similar issue)...What's weird is that the rear seal looks fine,..far better than the front....hope to have a good look when time for the upcoming (windows out-to the metal) repaint.
BEST!
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 02-21-2012, 03:15 PM
FPB111's Avatar
+1 for a new seal.
If you look at the way water sits on the lower corners of the window. You can see where it can sneak past as the seal dries out and loses its elasticity and grip on the window.
It seems to seep through more on the drivers (left) side. I think because that is where the power leads for the defogger come through the inner side of the seal making it a little weaker??.
The last time I had the seal replaced the installer injected some sealer "glue"? under the rubber lip on the window side. He said never put sealer on the metal side.
Old 02-21-2012, 06:51 PM
you see Arthur...
jasonlee's Avatar
thanks for everyones input. Going to take care of it tomorrow. Hoping that will solve the problem
J
06 Cayenne S
00 ML 55 AMG
Santa Cruz Bullit
Old 02-22-2012, 02:42 PM
El Duderino
tirwin's Avatar
Have you checked to make sure the sunroof drains are not clogged?
There are those who call me... Tim
'83 911 SC 3.0 coupe (NA)
You can't buy happiness, but you can buy car parts which is kind of the same thing.
Old 02-22-2012, 03:44 PM
you see Arthur...
jasonlee's Avatar
they don't appear to be I ran a wire up through them and all seemed clear.
J
06 Cayenne S
00 ML 55 AMG
Santa Cruz Bullit
Old 02-22-2012, 04:07 PM
NeedSpace's Avatar
Have you checked the radiator or water pump? hehe, sorry couldn't help myself. My money is on rear windows or door seals.
Old 02-22-2012, 07:03 PM
rsscotty's Avatar
The sunroof cable guide tracks have a plastic locating pin that indexes into the inner roof in the rear. This must have sealer on it or you can get water in the interior.
Old 02-22-2012, 07:11 PM
i had believe it or not a front windshield leak and water runs under the front carpet and gets wet on rear carpet hard to believe but it is true.
Old 02-22-2012, 07:49 PM
I tried Everything suggested and finally did a test to really find out! I taped over the Sun roof, rear window & side windows and Everything stayed Dry. I removed the window tape and still no water which brings me to the Sun Roof! I have cleaned the drains and sealed the plastic pin and now believe that the roof drain is Rusted out!
I plan to remove the headliner on the side and See If this is the case! There are NO other explanations!!
Old 02-23-2012, 11:29 AM
you see Arthur...
jasonlee's Avatar
rscotty, you don't happen to have a picture of said pin location that requires sealer but chance.
J
06 Cayenne S
00 ML 55 AMG
Santa Cruz Bullit
Old 02-23-2012, 02:26 PM
