bonedaddy's Avatar
Ground strap to nowhere?
Hmmm. Had my fan out and noticed a ground strap, about 4-5" long which is attached to one of the bolts that joins the crankcase halves. Trouble is, the other end goes nowhere, and I can't see a logical place for it. Can anyone tell me?
Old 04-21-2002, 06:10 PM
it grounds the alternator better than the housing to case contact area does, which often has corrosion on it. attach it to the nearest stud that holds the fiberglass air duct onto the rear of the alternator.
206 637 4071
Old 04-21-2002, 06:52 PM
GIBSON's Avatar
I'm playing around with this stupid image editing software.
I had to give up Photoshop when I switched to a PC (rather have the Mac..). This program came with the computer.
Anyway, here's my rendition of where the ground strap goes:
Old 04-21-2002, 07:22 PM
tight as a bull's ass's Avatar
I believe Gibson is correct
www.swirlednews.com/article.asp?artID=501
The data in the CD-type disc decodes easily into ASCII computer text as follows, using 8 bit binary:
"Beware the bearers of FALSE gifts & their BROKEN PROMISES. Much PAIN but still time. (Damaged Word). There is GOOD out there. We OPpose DECEPTION. Conduit CLOSING (BELL SOUND)”
The damaged word would appear to be intended as “BELIEVE”.
Old 04-21-2002, 07:30 PM
bonedaddy's Avatar
Gracias. It was tough getting to it (I need smaller hands), but I managed.
Old 04-21-2002, 08:22 PM
